Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Have got a husqvarana 235e 16" bar, what size chain do i need please,thanks.
  • 710 Answers
Hi Simon, \
The chain specs are .325" / 3/8"
Hope this helps. If it does, please place a vote. Thanks,
Handie Andie
Posted on Apr 03, 2011
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
How do you replace a fuel filter for 235e husqvarna chain saw
They are kinda hard to get them out but it is in the fuel tank on the fuel line just get it out the gas tank filler hole then pull off and replace with new one..
Jul 15, 2014 | Husqvarna 235e 16-inch 34.4cc 2-stroke...
How to get chain guard off 235e husqvarna?
The chainbrake must be open, then turn the chain tightening handle counter clockwise. The side cover can then be removed.
Apr 26, 2014 | Husqvarna Forest & Garden #952802239 235E...
How to replace a missing throttle push rod 141 husky???
It is very simple to re fit, you only need to lift the top cover off, the hooked end of the rod just engages into the hole in the throttle spindle, the other end with the plasric sleeve just sits into the groove in the tank unit, and is held down by the top cover, the part number of the rod is 530029869 the plastic sleeve is part number 530029863
Jul 10, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you replace a chain on a Husqvarna 235e
Take out the chain guard.Once there you will look at a bolt holding the chain plate.Untight the bolt and adjust the cahin,but not too tight just test by hand if it moves freely but tight.Usually a gap of about 1/4 or less is enough,tight and guard back.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | Husqvarna Forest & Garden #952802239 235E...
Problems with the 350 husqvarna bar.
If all you say is true and when revved up the saw oozes oil with the bar removed, then I suspect the bar is incompatible with the saw. Has the bar been replaced? The oiler holes in the bar must align with the channel in the saw. Oiler hole placement is part of the reason there are so many different part numbers for bars. The mount is only part of the requirement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Husqvarna Forest & Garden #952802239 235E...
The bar and gear cover will not go back on. The
The metal band is the chain brake . It must be compressed so you need to move the brake handle forward.
Feb 01, 2010 | Husqvarna Forest & Garden #952802239 235E...
Chain brake will not reset
Hello. If you haven't done so already remove the bar and chain. The chain brake mechanism is behind the clutch.Clean the whole area with compressed air or a scraper and a shot of engine cleaner if you have some. Look for broken, bent ,stuck or missing parts.
builderdale
Jan 07, 2010 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
63 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
