Question about GE JBP82 Electric Kitchen Range
I have an older model (70's?) GE Double electric oven. I wish to clean under the burners but can't figure out a way to open the top. Is there a way to do this like you can on newer mosels?The model # is JC566OW1HA.
  • 4 more comments
  • hvantassell Apr 03, 2011
    The problem I am having is that there are no screws or latches under the main top, so I can't get it opened. I do not have a glass top oven. It is an older double electric range with the coil burners. Any ideas? Thanks
    This was postedunder the wrong heading. The model is a GE JC566 OW1HA
    This was posted under the wrong heading. The model is a GE JC566 OW1HA .
    The issue is how to open the main top of the range. Thanks
    Thanks but this does not give detail onto how to lift up the cooktop, which is what I am in need of. This model does not have a latch and won't easily lift up.
  • hvantassell Apr 04, 2011
    It is not a JBP82. I'm unsure how that appeared in the question title. It is a JC566 0W1HA and it is much older...probably from the 70's or early 80's. It is Harvest Gold in color which should give you a better indication of the year. There are no screws under the range top holding it into place. It seems to be latched on each side but there is no place to release the latch. I have searched GE's site as well and they state that after 92 they started making models with an easy lift top for ease of cleaning. Perhaps this means that the top does not lift on this model?
  • hvantassell Apr 05, 2011
    Yes this is a double electric oven. It does not have the easy open as the manuel shows. I will give the putty knife trick a try though. Thanks
    Guru:
  • 262 Answers
I'm confused as to the numbers that were posted. The JBP82 model is a glass cook top and the model number that was posted can not be found.
However if it is a older model try this. Open the top oven door....look under where it meets the range top when closed. There are screws mounted that you need to take out.
Now try sliding or lifting the top.
Still confused on the numbers posted.
I have an older model Problem with the GE JBP82 Electric Kitchen Range I have an older model (70\'s?) GE Double electric oven. I wish to clean under the burners but can\'t figure out a way to open the top. Is there a way to do this like you can on newer mosels?The model # is JC566OW1HA try this when searching the model number.
Link for all appliance model numbers.
Please post your entire model number.
After you have clicked on the link below....
Just to the right of the "search" tab click on "help me find my model number"
Just click on the model of your choice In either video or image presentation
Then please repost the information.
Click on the link http://www.repairclinic.com/Appliance-Parts
Thanks....
Keith
Posted on Apr 03, 2011
  • 1 more comment
  • Keith Drake
    Keith Drake Apr 04, 2011
  • Insert a large blade putty knife between the stove top and the control console close to the front corners. Slide the putty knife in to release the retaining clip that secures the stove top to the front of the range.
  • Lift up on the front of the stove top. Pull the stove top forward to disengage the rear of the stove top from the rear hinge. Or the top may just lift up after disengaging the clips
  • Still have found nothing on the model number posted.
  • Keith Drake
    This is as close to the model number that was posted as I could for a user manual.
    JCS57, JCP67
    However this is a electric unit.....double oven with one on the right(large) and one on the left (small)
    I blieve is was made in the 70's
    Here is the link http://kitchen.manualsonline.com/manuals...
    If you can not download the manual email me kdrake84@yahoo.com and I will forward it to you.
    It says in the manual...to disconnect the heating units....by lifting them 1 inch only and then pulling them out. This will allow you to get the drip pans out.
    To lift up the top....simply lift the top....it will have a support rod where you can rest the top on.
    From the manual......
    To lift the cooktop:
    1. Remove all items
    which may slide off
    the cooktop.
    2. With both hands,
    grasp the front edge
    let the cooktop rest on it.
    of the cooktop.
    3. Lift the cooktop.
    4. Raise the support rod and
    Clean under the cooktop with hot, mild soapy water
    and a clean cloth.
    To lower the cooktop:
    1. Lift the cooktop and lower the support rod.
    2. Lower the cooktop and allow it to lock into position.
    1. Remove all items
    which may slide off
    the cooktop.
    2. With both hands,
    of the cooktop.
    and a clean cloth.
  • Keith Drake
    here is the heading of the download
    GE Electric Ranges Use and Care & Installation Guide JCS57, JCP67
    for General Electric JCS57 Range
    Looks like this should work.Note the jcs57 range
    • 4,323 Answers
    Hi
    This model is quite old and the parts/diagrams are also not available however you check the video, it can open simply and then burners take out to clean:
    Hope this helps...please post back for further assistance.
    Daniel
    • GE Master
    • 1,902 Answers
    Hello & Welcome to FixYa
    Please check this video for cleaning under the burner, however it is for burner replacement but will help you in cleaning as well:
    Please get back to me if you have any other questions.
    Kevin
    I have a maytag gemini electric double oven stove. The cooktop works, but neither oven works. I recently set the timer on it, and had a very hard time figuring out how to set it. Could that be a c
    You should have a tech sheet in a plastic sleeve on the back of the oven towards the top if not there shoot the model number so i can look up code don't wish to guess they change too much
    Feb 13, 2015 | Maytag 30" Self-Cleaning Freestanding...
    I lifted the stove top of my hotpoint electric stove to clean under the burners and now I can not get it back in place
    There are two metal brackets, thin ones, like little wires, one on each side, holding the stove top up. They are held in place by clicking toward you slightly when you life the stove top, push them back toward the wall slightly to release them.
    Good Luck!
    Nov 20, 2013 | GE Profile 30" Self-Cleaning Freestanding...
    Cleaned bottom oven. Top oven door won't open
    Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
    Also check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
    Double oven, top oven run by keypad turns off
    I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
    Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
    I have an older GE self-cleaning oven. It has an
    Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
    Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
    Lower oven burner will not light.
    Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
    May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    I have an old (20 years +) Tappanr 4 burner range with a double oven. I am missing the knob for the cleaning cycle but it says it is self cleaning. I need a replacement. I'd also like to find replacement...
    chances ar erte hlower oven door , is your broiler, the older models didnt have a seperate broiler inside oven, rather they used 1 burner bar ,and depending on wher oyu place the food you would either bake(above) or broil( under) made sense, just pain in the rear to bend down to use it. as far a knob and gasket , perhaps you can find a model number under the main top assy so we can look up for you
    Mar 07, 2009 | Tappan MPF500PBW Gas Kitchen Range
    GE Elec oven JT952-30" blinks the "lock" after self-clean
    Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
    If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
    Enter model number here to find assembly diagrams and parts.
    Jan 02, 2009 | GE Profile JT952 Electric Double Oven
    GE Electric Double Oven Door Will Not Unlock
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
    GE JBP82 Electric Kitchen Range Logo
    306 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
