Question about Vacuums
Dow do I turn off DST feature on Timex T248T - Vacuums
  • 710 Answers
I've looked at the user manual for this model. It doesn't look like it has a daylight savings time feature. Does yours? It looks like you have to set the clock forward and back yourself for time changes.
Here is the owners manual for this model of clock: http://www.timexaudio.com/pdf/T248_IB43485_62.pdf
I hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Posted on Apr 03, 2011
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Help! My food processor doesnt turn on. Is there a safety feature that I dont know about. Evertything is locked in place.
Hi jessi...the safety feature is built into the lid. once the lid is securely in place it should operate. Without the lid properly in place it will not. Joe
Apr 17, 2011 | Vacuums
I purchased a Timex T308S Nature Sounds Dual Alarm secondhand and need an owner's manual so that I can figure out how to operate it.
He,
Here is a webpage with the pdf document: http://www.timexaudio.com/pdf/T308_IB57357_15.pdf
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Apr 02, 2011 | Vacuums
Model 31320 SkyScan Equity Time Clock -- it did not change with DST but I cannot figure out how to manually set the time. Back of clock shows 4 long...
You press and release the mode button, then press the adjust button. This is what the instructions say to do. However, I see that you don't have an adjust button listed. I would try pressing and releasing the mode button, then pressing the ZONEDATE button and see if that will do it.
If this works, please place a vote for me. Thanks,
Handie Andie
Mar 27, 2011 | Vacuums
How do I set a Omexey RT018B clock as I have lost the instruction book!
Press and hold the "Alarm set" button at the same taime as "DST Set" button this will then cause the year to start flashing
Adjust all settings with the + & - buttons (use "Alarm set to accept each option.
The time is the last in the sequence
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
Want manual for TIMECO WR 30M digital watch
You can get the manual on the link below.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Good Luck and please rate 4 thumbs up for the free answer
Aug 02, 2010 | Vacuums
I have no suction power but the brush feature will turn on & spin
the same motor that turns the belt is sucking at the same time. your prob is just behinde the brush there is a pickup hole. tahe a wire coat hanger and shove it through unti you see it were the hose plugs in the back off the vac. ming did the same thing and i see these in the trash all the time. I clean the shoots and sell them on craigs list. if it was the reset you would not have any power at all
Jun 13, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
