Question about Toshiba Televison & Video
Hi, Need users manual for Toshiba 37XV505, picture gone tv only 4 months old, Help
    Scholar:
  • 67 Answers
A user manual will do you no good for a tv that has lost its picture. You will need a service manual. Your tv sounds like it's a 37 inch lcd or plasma tv. The cause could possibly be puffed capacitors on the power supply. If you feel confident, you could check the power supply pcb and visually look at all the caps on it to see if they are puffed.
To do this you need to lay the tv face down on a cushioned surface large enough to support the tv by the frame. This is to prevent any damage to the panel. Then remove all the screws securing the back of the tv to the frame. Look at the power supply pcb, it is the board with the power cord attached to it, for puffy caps. If they are puffed they need to be replaced. Replace with capacitors of equal or slightly greater values. The values are marked on the caps themselves in mfd and voltage.
If they look good, take a multimeter and test the dc voltage outputs, usually marked on the power supply near connectors with different colored wires. There should be three of them together. Take the black lead of your multimeter and connect it to chassis ground, and the red lead use to check the voltages.
Posted on Apr 03, 2011
Toshiba regza tv switches on but has no picture or sound
I can try to help but: what is the model number and how old is this set? Model and date made will be on rear of set.
Dec 19, 2012 | Toshiba Televison & Video
7inch vertical color lines right side of screen all th time
Hi.
This website has the service manual ($7.79) with instructions to diagnose the boards. Unfortunately I am afraid that the problem is not a board but the panel itself.
Thin vertical lines in the middle of the picture mean that the panel is gone. Here an example of lines from bad panel in Toshiba LCD:Line Picture. (discussion: Avsforum). Sometimes the lines can be dark or in bright color.
The panel costs $339 (LCD PANEL ASSY).
Because of the price of the panel, the TV is not worth repairing unless under warranty.
Even if the TV is out of warranty call Toshiba and report the problem. As you can see in AVSforum page above the problem is affecting many users.
If Toshiba doesn't offer special conditions on repair (or discount on new), the TV is not worth repairing. Replacement of the digital board will hardly be a solution.
Only if you have wide bands, scrambled or flickering, then the problem is digital board (main board) or panel.If you have the thin pixel lines, then the panel is gone.
Dec 10, 2011 | Toshiba 40RF350U 40 in. LCD TV
How to i change the picture from antenna to cable?
TV/CABLE function
1 Press MENU, then press S or T until the SET UP menu appears.
2 Press up/down arrow button on remote until "TV/CABLE" is highlighted.
3 Press to highlight either "TV" or "CABLE", whichever you use.
Hope these info will help you.
Let me know if you need user manual free copy of Toshiba 50H72 tv.
Thanks.
Jan 05, 2011 | Toshiba 50H72 50" Rear Projection...
No Picture on 5 month old tv.
If the screen is just showing white screen, no text, no picture, then the problem cam be in the LCD controller board. I would get this fixed under warranty ASAP, nothing should have gone wrong yet. You may have a lemon, this is not a no name set.
Jan 02, 2010 | Toshiba 26LV610U LCD TV
I just heard a loud pop and my picture went to out
the service manual is available in the web site andrewselectronics for sell.
there is a chance to inspect the lamp and see if is damage (normal failure for this popping noise) consult you user's manual ...How to replace the lamp. as i said inspect it and replace it as needed, use original lamp. Toshiba
Feb 23, 2009 | Toshiba 62HM95 62" HDTV
Hi, i have a problem with my toshiba regza, 32" about 18 months old, keeps changing screen width to 4:3 from widescreen on some of the music channels on sky! keep resetting it but still does it next...
Hi Debbie,
Check the picture format setting on your Sky box.
Press Services.
4 for set up.
1 for Picture.
Theres and option that says 16:9, 4:3 or 4:3LB, make sure its set to 16:9.
Then go to Save settings and press the Select button to save the setting.
Regards
Andy
Jun 26, 2008 | Toshiba Televison & Video
Toshiba tv - no picture
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 04, 2008 | Toshiba 57H81 57" Rear Projection...
Dark Picture
this problem is due to 1 not proper voltage on crt terminals 2 check video output supply voltage 3 check luminance section of chroma ic 4 if tv is very very old than there is a possibility of crt getting weak
Jul 30, 2006 | Toshiba 27A34 27" TV
Televison & Video Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
