Question about Toshiba Satellite C655S5052 (2501493) PC Notebook
I am trying to burn a DVD to DVD and I am getting an error code of 060277-26-53052C00. I tried to do this twice with new DVDs and made sure they were clean and they were. It will take the information from the DVD that I want to copy from but will not burn it to the other DVD.
3 Suggested Answers
hitman505
  • 14 Answers
SOURCE: Toshiba Satellite P200
Can you play a dvd movie if you can try reinstalling your dvd burning software. nero could have a corropt file if you are using this. If you cannot play any dvd and does not recouldnize any dvd disk their could be a problem with the device. I have not seen this error code before.
Posted on Jan 20, 2008
rtrahan
  • 741 Answers
Couldn't find that specific error code anywhere. However to give more information try this. Try to burn a CD, when you get the error code go to:
Control Panel>Administrative Tools>Event Viewer then Services and Applications. See if you get an "error" on a particular application you should as the event viewer documents everything that goes on in the system. Let me know what application or file is causing the error..standying by.
Posted on Mar 12, 2009
Getting a problem burning 6 files to my dvd. Im get an error after about 2/3 of the burn. tried it with 3 different dvds and one re-writeable. Always getting an error saying to clean the disk or try...
make sure that the dvd burner is getting enough consistent power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Jan 02, 2011 | Pioneer DVD±RW Burner
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
DVD's won't finish Formating. Getting error message: Windows was unable to finish formating. DVD Burner smelled weird, like hot plastic. Worked fine before never had a problem. What could it be ? Is the...
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 28, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Won't complete initializing. Just keeps going. Doesn't move on.
Aug 17, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
After burning home movies on dvd - they won't play on dvd player or computer --- says disk error. Software says disc was successfully copied
Be sure you purchased compatible discs for your DVD player, ie. DVD +R or -R. Some players won't support both.
Jun 24, 2009 | JVC Everio GZ-MG21 Camcorder
Error burning to Dual Layer DVD
Do you have a dual layer burner, you need one to burn dual layer dvds that may be your problem hope it helps
Mar 25, 2009 | Global Marketing Partners Vhs To DVD 3.0...
Cd burn
Either the drive is bad or your using the wrong type of blank dvds.Try using DVD-R or DVD-RW for betters chances of success.Sometimes some of the new DVDs are bad.Make sure you try a couple different ones even from a new pack of DVDs.
Jul 22, 2008 | Toshiba Satellite A105-S2716 Notebook
Problem burning DVDs
This happened to me also. I fixed the problem by buying new DVD discs, sometimes the mac's rom doesnt like particular discs. Its a trial and error thing with which ones it will use. Make sure you are using the latest version of Roxio toast to burn with, also make sure your ROM is DVD-R.
If all this fails, it could be your writer in the rom. Try burning a CD, if that works it will be the above problems.
Try using discs with a GOLD BOTTOM, it seemed to work for me.
May 06, 2008 | Apple Power Mac G5 Desktop
Toshiba Satellite C655S5052 (2501493) PC Notebook Logo
202 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
