Question about HP W2338H Monitor
HP W2338H Monitor FIRST hums- loudness increases then after 10 min. or so screen goes black
2 Suggested Answers
app_3rp77890
SOURCE: I have the HP w2338h monitor. when i listen to
I know this post is kinda old and dead, But the solution to this problem in some cases is with the color balance in the screen. If you can rush this before the screen turns off you can try this. Turn on the monitor go into the menu and adjust the brightness all the way to 100% you will notice the humming will stop, if it still shuts off try going down to 0% (0% worked for me I now use this monitor as a xbox / ps3 screen.
www.pcdunrite.com
Posted on Apr 10, 2012
Screen goes black + loud hum
Hi,Dear User...
I think you screen goes to damage. Please follow instruction
1> Monitor power come or not.
2> Monitor cable is ok.
3> Open it up and check that all the fans are working, and that
there are no dustbunnies floating around.
4> If the graphics card has a fan, be extra attentive. Check it
Thanks..
Jan 22, 2013 | HP W2338H Monitor
No input signal message and screen goes black
Check your video cable going from your monitor to the pc. If your trying to use more than 1 monitor, is your video card capable of using more than 1? Are you using the mother board video card or a store bought one?
Jul 22, 2012 | HP W2338H 23-Inch Widescreen Monitor
Power button lockout is on how do I turn it off
to remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away.
== see if this helps==
Feb 02, 2012 | HP W2338H Monitor
My HP w2338h has a series of different colore bands on the right side of the screen. What is the cause and can I repair it myself
Is the picture still visible? If it is yes you just need to factory reset the monitor. If not, check your inverter.
Mar 09, 2011 | HP W2338H Monitor
W2338h goes black after 2 seconds. Can I fix it myself?
If this is due to the capacitors failing, I'd advise not, unless you are competent in identifying and testing these. My advice is to take it to a reapair shop
Feb 12, 2011 | HP W2338H Monitor
I have a HP w2338h monitor that goes blank
It is most likely a bad power supply... I have had aboit 4 diff monitors do this to me... most common is under rated capacitors in the internal power supply... some times there could be a black light going out witch causes higher current draw on the power supply ( witch can take out the caps, fusses, transformers ( caps and transformers when they get week and bad can cause the buzzing sound ( on some times with a radio near buy then the monitor is acting up with blanking out and buzzine the radio will pop and buzz as well witch is a sign that there is arching going on IE. caps and transformer are most common for that )))
hope this info helps
kc7wzl
Jun 23, 2010 | HP W2338H Monitor
Hi there , Go to your PC settings , and Try turn Screen saver off , aswell as Sleep off... it is in your PC settings.
Good luck
May 22, 2010 | HP W2338H Monitor
No volume from hp w2338h monitor...only sound comes from headphones pluggedinto computer
check if the monitor speakers are the default speakers for ur computer.. to do so.. click Start.. then under start search type.. Sound.. and hit enter on this screen u shall be able to see various devices as speakers.. the one with Green check is the default speaker.. select Monitor and select Default below and thts it.. ur done.. for more info.. go to the following link from HP http://tinyurl.com/2fvjh7l
let me know if this was helpful to u.. regards, guru
Apr 18, 2010 | HP W2338H Monitor
I have a HP w2338h that has started buzzing loudly and the screen will go blank quite frequently. I have to power on/off and also move my mouse and type on the keyboard to get the screen to display again
You may have failing components in the power supply.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | HP W2338H Monitor
HP W2338H Monitor Logo
243 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
