Question about Video Game Consoles & Games
Wii can't connect to Internet code 52030 - Video Game Consoles & Games
  • 2,632 Answers
If you want to connect you Wii to the internet wirelessly first we need to know the settings of your router. Listed below are the steps on how to access your router. You need a working computer connected to the router to access it follwed by the steps on how to connect our Wii.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Now that we have the information needed lets connect your Wii to the internet.
1. Select Wii Settings
2. Then Internet Connection Settings
3. Search for an AP or SSID
4. Input Security Key or Network Key
5. Test the Connection.
Other Suggestion
Did this connection used to work but has suddenly stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii and test for proper response.
The Wii may have detected and set itself to the wrong security type during the initial connection set up. Try creating a new connection file and going through the connection process again but be sure that when the Wii asks for a security code, the type shown on screen (WEP or WPA) is what your router is set to. If it is different
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
If you have questions please let me know. Thanks for using Fixya
Posted on Apr 03, 2011
Can not connect to internet on my wii error code 52030
It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console
Jun 04, 2012 | Nintendo Wii Console
Tip
Nintendo Wii Error Code 52030 The most likely cause of error 52030 is that the...
Nintendo Wii Error Code 52030<br /><br />The most likely cause of error <b>52030</b> is that the router securityinformation was entered incorrectly on your Wii or that your router is unableto assign an IP address to the Wii.<br /><br />If this problem <b>just started</b>, and your Wii was working before, then tryto <b>power cycle</b> your equipment. Turn off the modem, router and Wii. After10 seconds turn on the Modem, after 30 seconds turn on your router, and after30 seconds turn on the Wii.<br /><br />If this does not work then continue below,<br /><br /><b>Make sure</b> your wireless <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>network<span>security</span></span></span></a> password and security typeis entered into your Nintendo Wii correctly. You can go into your routersconfiguration page to view the security key and view security type. If needed,you can change these. On most routers, you can access the configuration page byopening your Internet Browser and going to the router ip address(gatewayaddress) 192.168.1.1 This address may vary from router to router. Once you goto this address you should get a login page. Login and then go to your Wirelesssettings page to view the settings you need for your Wii. Once you verify thesecurity key and type, input these settings into your Wii and test theconnection. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> for my <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>tech</span></span></a> article on how to configureinternet settings on the Nintendo Wii.<br /><br />Tip - To view your gateway address in Windows do the following,<br />Go to Start &gt; Run and in the run box type "command" or"cmd". A black DOS window should open. In this window type"ipconfig /all" you should <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>now</span></span></a> see a gateway address.<br /><br />-<b>Most home networks </b>will use DCHP. What is DCHP? This is Dynamic HostConfiguration Protocol. In short, it means your router or <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>server</span></span></a> will assign IP and DNSaddresses out automatically, with no intervention needed from you. If you aremanually using settings(not using DCHP) you will need to assign an IP/DNSaddress to your Wii.<br /><br /><b>To get </b>to the Wii settings to input an IP address and DNS address, dothe following,<br /><br />Access the Wii System settings and select "Internet" from Page 2.<br />Select "Connection Settings" and choose the connection file youcurrently use (will have a red border around it).<br />Select "Change Settings," and click the right blue arrow twice toreach "Auto-Obtain IP Address."<br />Click on "No" and select "Advanced Settings."<br /><br />Enter in your IP address, DNS address and subnet mask information.<br /><br />A Wii connection test should confirm the internet is now working. Again, mosthome networks use DCHP so you may not need to set an IP address.<br /><br />-<b>Interference</b> can also cause this issue. Try and make sure there are nowireless devices around the Wii and router and the Wii is in an open areawithout devices blocking it.<br />-<b>Change your router's channel</b> setting to 1 or 11. By default, mostrouters broadcast on channel 6, which overlaps with other channels and may beweaker.<br /><br />If you are still having trouble, you may want to reach out to NintendoTechnical Support at 1-800-255-3700<br /><br />-G33k<br /><br />Check out some of my other tech articles!<br /><a href="/../support/r9300521-nintendo_wii_error_code_51031">Nintendo Wii Error Code 51031</a><br /><a href="/../support/r9300387-tuneup_utilities_prefetch_data_deleted">Tuneup utilities prefetch data deleted</a><br /><a href="/../support/r9275311-computer_freezes_computer_stuck">Computer freezes, computer stuck</a><br /><a href="/../support/r9256225-disable_enable_microsoft_windows_startup">How to disable/enable Microsoft Windows startup programs</a><br /><a href="/../support/r9223119-garmin_gps_stuck_not_updating_no">Garmin GPS - stuck , not updating, no signal problems</a><br /><br />Keywords<br /><b>Nintendo Wii Error Code 52030, Wii error code 52030, Wii 52030, Nintendo Wiiinternet issues, Wii internet, Nintendo Wii internet</b>
on Jun 02, 2011 | Nintendo Wii Console
We can't seem to get our Wii internet connection to turn on, they give us error code 52030
This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again
Aug 23, 2011 | Nintendo Wii Console
Lost internet connection reading code 52030
Error Code: 52030
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
Jul 20, 2011 | Nintendo Wii Console
Wii will not conect to the internet today, we have not had a problem before today. When I test it it shows an error code of 52030.
The following information was taken directly from Nintendo's website about error code 52030. I have included a link at the bottom directly to the page from which I got this information. If you click the link, there will be a step by step guide on fixing the error:
Error 52030
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=en_US&action2.x=29&action2.y=19
Apr 07, 2011 | Nintendo Wii Console
When I try to connect to the Internet it keeps giving me a error code 52030
Error 52030 is a security settings error built into the Wii. This means the Wii is either incompatible with your router's security settings or your router isn't able to assign the Wii an IP address (which means it can't register it onto your network).
Nintendo has provided official information for solving this problem here: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
Mar 12, 2011 | Nintendo Wii Console
My wii will not connect to wireless internet error code 52030
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
Feb 28, 2011 | Nintendo Wii Console
I have an Error Code 52030 on my WII. What does
it means that u are trying to connect to wifi but there is no wifi around so go 2 tech support for wii and enter the error code.:)
Jan 30, 2010 | Nintendo Wii Console
Wii shop channel won,t work
YOur internet isnt allowing the wii to access the shop...
Apr 22, 2008 | Nintendo Wii Console
Error 52030 in internet connections
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right afer started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Nov 23, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
