Question about Roper Dryers
A shoe lace got stuck between the turning drum and the houseing ,it not turn back on RES7745RQO
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: Drum won't spin
first of all never dry shoe laces in a dryer a=or anything simular to it. The drum has a very thin seal between the front edge of the drun towards the front panel of the dryer. That front panel will be needed to be removed so you can clean the seal out really good and thoroughly inspect it for tears, rips or and missing peices. If beyond using replace it. While you are in there inspect the belt around the drun and tensioner too. The belt should be tight without cracks in it and the tensioner & bearing should move freely for good performance
Posted on Feb 06, 2010
Cant get drum back on how do I adjust the brake pads
The brake shoes can be adjusted inward by the self-adjusting mechanism at the bottom of the shoes. Turn the adjuster wheel so the shoes will just fit inside the drum. After you get the drum on, use a screwdriver through the slot on back of brake plate to turn the adjuster wheel enough clicks outward to where the shoes are just away from the drum. Turn the drum by hand. When shoes are out enough without stopping the drum, you have it right. When all done and testing out, the self-adjusters will set adjustment by backing in reverse and hitting the brakes. Do this two or three times-you may hear the self-adjusting wheel click with each time- it is adjusting the shoes to the proper distance from the drum.
Oct 13, 2013 | 1997 Plymouth Grand Voyager
How do i remove rear drum on 1997 ford f 1-50
If the brake shoes have worn into the drum, you would need to turn the adjuster back to release the shoes.
If the drum is stuck to the axle, you would need to spray the axle with penetrating oil and use pry bars to pry the drum off.
Jul 12, 2012 | Ford F-150 Cars & Trucks
The patent leather on my laces are coming off took them to a shoe repair he said nothing he can do help I want to wear my shoes
Theres the obvious which is get new shoes because they do still make them, but there are other solutions. One you can wear the laces as they are. Two you can look online to find new laces, but they are extremely hard to find. Three look for laces that are similar but can replace the laces. Four buy a used pair just for the laces. Now all of these will only work if they laces can come off. If not then there is nothing you can really do to fix the laces the way they were unfortunately.
Jun 03, 2011 | Rocawear Sofi Sandals for Women
How to remove rear brake drums
Most rear brake drums that will not come off are stuck due to the shoes inside pressing on the drum. Also, most rear brakes have a small access hole used for adjusting the shoes either in or out...you will need to back off the shoes in order for the drum to come off...you use a screwdriver in the slot and turn the adjuster...there are "teeth" as with a gear on the adjuster and you either go up od down...if you try to back it off and it will not move or the drum wont come off then you need to go the other way
Jan 08, 2011 | Ford Fiesta Cars & Trucks
How to adjust rear brakes shoes on toyota corrolla 1999
the shoes on drum brakes should auto adjust by backing up and applying pressure to the brake pedal (you may hear a clicking noise from the springs on the adjustment stars as they turn). If this does not work, the mechanism may be broken, aligned improperly or stuck by corrosion. Most drum brake assemblies have an access hole in the drum or backing plate to make manual adjustments, comment back to me if u have these access holes and I will walk you through the procedure...(check your shoe lining thickness as you may just need new brake shoes)
Oct 01, 2010 | 1999 Toyota Corolla
Wondering how to get to the brake shoes to change them , cant get the drums off
the drums are stuck because a groove the width of the brake shoes is worn into the drum causing a lip on open end of drum. you will have to force the brake adjusters to loosen shoes. it isnt easy to do but you got to take a small screw driver and push the ratchet that tightens the brake shoes away from the teeth on the adjuster wheel then turn the wheel to loosen. i sometimes would just cut off the hold down pins from the backside of the backing plate then just carefully pull drum off so as not to damage the wheel cylinder and other hardware
May 09, 2010 | 1999 Plymouth Grand Voyager
Drum won't spin caused by piece shoe lace got stuck in drum. dryer was still on but drum not turning.
Feb 06, 2010 | Dryers
Passenger side rear brake locked up.
It's probably the emergency brake cable that is stuck. Check that first. When I get a drum brake that is totally frozen up (like been sitting for 40 yrs) I often use 2 or 3 pry bars, WD40 and short handle sledge hammer to pry a little on both sides, liberally keep penetrating oil squirted on the shoes and tap on all sides. Eventually drum will come off, but sometimes it takes like maybe 1/2 hour. Shoes will have to be replaced, but they are probably shot anyway. The drums for the caravans are cheap, so I would not only get them, but the spring kit from the parts house as well.
Apr 11, 2009 | 1999 Dodge Caravan
I have a LG front load washer, and a shoe lace got stuck in the little holes on the back. The end of the shoe lace is made of some hard materials and it gets bend, so got stuck in the little hole. I...
Ouch! I'm guessing that the shoe lace wrapped around the shaft from the inner tub and cannot be pulled back into the wash tub. That sucks, because the only way to get at it then would be to remove the motor rotor, sepperate the two halves of the outer tub, allowing the inner tub to be removed to access the offending shoe lace. If you know what you're doing, it's about a two hour job. My advice: Just live with the noise. Please don't bother rating this, as anything but a Fix-Ya drops my score.
Jan 03, 2009 | LG WM-2277HW Front Load Washer
Dryers Logo
51 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
