I have a 37" Sharp
  • 961 Answers
What is the cord you are using? In your computer, click on "start", then click on "control panel". Find and right click on "device manager", open and click continue. Click on the box(right side) of "monitors". Do you see your tv in the list? Do you see any warnings, ?, !, yellow triangle? If so click on that and follow proceedure. Right click on your device(your tv). In the list you should see "disable". If you see "enable" click on that and exit. Restart your system and you may see your system upgrading to a driver that will help in providing the picture to your TV. Recheck you TV in device manager again.
Posted on Apr 03, 2011
  • 3 more comments
  • 9joelle Apr 03, 2011
    Hi, thank you for responding. I'm using a VGA cable and have Windows XP. Under monitors in the device manager it just lists one- plug and play monitor- no yellow triangles or warnings on it. A thing called network controller has a yellow exclamation point on it. Each time I need to see the computer screen I have to unplug the cable from the TV and plug it back into my monitor, so I don't know if that's making a difference, but otherwise I have no way of seeing what I'm clicking on etc.
  • David Petry Apr 03, 2011
    You need to click on that exclamation point and see what it recommends using the other monitor.Have you restarted thecomputer with the tv hooked up? Try shutting down computer and uplugging tower for i mnute. Hook up tv and restart. Windows should try to read new monitor and may install a driver necessary for the tv. If you still have no picture, given enough time for resatrt. Shut system down again and start in "safe mode". Now go into device manager and click on monitor and see if your tv shows up in th list.
    Make sure it's "enabled".
    I'm using a VGA cable and have Windows XP. In the display settings tab I did try both the 60 & 75HZ, made sure that the boxes to use as my primary monitor and extend my Windows display to the monitor are checked. In the device manager tab under monitors it lists only one- plug and play monitor. I'm unplugging from the TV and reconnecting to my regular monitor so I can see what I'm checking and what to do.
  • b armstrong Apr 04, 2011
    Try adjusting the resolution to a more standard resolution for your TV.
    Right click anywhere on the desktop and choose "Properties"
    Then click the "Settings" tab and choose either 1366 x 768 or 1920 x 1080 if available.
    The PC might be sending the image right now, but the TV isn't recognizing it as a resolution it can handle. TV's typically don't have the same native resolutions as PC monitors.
How do I display PC screen onto Sharp TV LC26SB24? I've lost TV user manual
Depending on your OS on most computers you need to either add a second monitor output or change the settings to tell the PC to redirect the video output to and external device instead of the PC's screen. Check your OS settings.
Jan 01, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black cloud like fogged on Sharp Aquos 37"tv
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I'm trying to use my 6 yr old Sharp TV as a remote monitor for my MacBook laptop. The Sharp manual says that port 5 is the correct port for PC hook up. So, I'm hooking up the laptop's mini DVI port to the...
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 27, 2010 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
Sharp AQUOS 37
My friend fixed it but I have no idea how he did it.
Jan 18, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
How do i Adjust My 40 inch Sharp Aquos to 1080 p?
You do not adjust the resolution at the TV, the TV will adjust itself to display what you are feeding it. It works the same way as the computer monitor, which is done on the computer's video card to what ever you set it to.
Nov 09, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32&amp;amp;amp;quot; Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-37GD6U 37 in. HDTV LCD.
I've had this problem with my Aquos. I had Sharp send out a tech. and they upgraded the firmware on the motherbd. to version 1.04 (main and monitor) and this took care of the problem
Sep 16, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
