Question about Sony Handycam DCR-HC90 Mini DV Digital Camcorder
I have a Sony DCR-PC90. When I insert a cassette, and push the cassette drawer closed, nothing happens -- no whirring noise, and the drawer doesn't lower into position. After about 60 seconds, it pops open. No error codes on the screen. The same thing happens if I push the drawer closed without a cassette. I've tried removing the battery, and resetting with the reset button. Everything else about the camera appears to be working. What can I do to fix it, or what other tests can I try?
I have i want to tranfer my video record programme to my computer, but nor show
Posted on Dec 01, 2011
SOURCE:
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
My Sony DCR-PC0-109 had been working just fine. Then one day I was checking to see the available space on my tape, and the camera would not insert the cassette. I tried another cassette, thinking that was...
It seems that your cassette holding alignment has been disturb... Since Sony does not provide service manual, at home we can try our luck only....
Check out this, while inserting cassette analyse that which side of cassette is stucking and try to figure out causes for the same, that means check whether there is any displacement has taken place....
Jun 22, 2010 | Sony Handycam DCR-PC109 Mini DV Digital...
Sony dcr-hc38. inserted tape. hear beeps. screen states to "reinsert the cassette". it continues and wont play or record --Solution #1- change the mechnical assembley of casete ...Can you explain how to do...
try it without inserting cassette if it closes correctly and doesnt load with cassette then 99% problem is with drum motor.look out for drum motor connector remove it clean it with pencil eraser and try again if it works, fine or just replace drum motor
Jun 11, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Error C31:40 will not take in a cassette
After not using my camera (Sony HVR-V1U) for one week, I took it out for an assignment but the error keeps coming up C:31:40 asking me to eject the cassette. The camera never gave me problems before this.I have tried smacking it at the bottom with the flat of my hand, flowing it with a hair dryer, shaking it, opening the cassette door for hours but nothing seems to work. The sony technician says I may have to send it in for repairs can any one help before I have to resort to this?
Jul 31, 2008 | Sony Handycam DCR-TRV240E Digital...
Sony dcr-trv480 video camcorder error
I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
May 04, 2008 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
SONY DCR-HC39E
I had the same problem. I would suggest going to the service with it. The "head" needs changing.
Oct 13, 2007 | Sony DCR-HC39E Mini DV Digital Camcorder
Cassette drawer
the flexwire of the mechanism have a open line...it is so difficult to fix that cause that wire is like a strand of hair..in sony service they replace the whole assembly and will cost a lots and again it will happen again the same problem cause the space of that wire in the mechanism is too small...in our shop we modified that wire and become more durable that the original...
Jul 17, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony Handycam DCR-HC90 Mini DV Digital Camcorder Logo
226 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
