Washer will not drain TB displayed on panel any suggestions
    Problem Solver:
  • 9 Answers
Check pump filter. I have had this twice on my indesit washing machine. You have to take the front cover off the bottom and then unscrew the filter to check it. Be careful as it will gush with water if the drum isn't drained.
Check the drain pipe for blockage by disconnecting far end of it and lowering to floor level (in a bowl). If no blockage then water should drain out of the drum by gravity.
Posted on Apr 03, 2011
How do you fix e20 code
Hello John, thanks for your inquiry!
From my understanding your Frigidaire front load washer is displaying an error code of "E20" and you would like to know how to fix it. An "E20" code stands for water is not pumping out fast enough this could be a problem with your drain hose, pump, or control panel. I would suggest checking the drain line to make sure it is not restricted. If the line looks clear it could be a problem with your drain pump or control panel. I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Apr 23, 2015 | Frigidaire GLTF2940ES Front Load Washer
I have 5d code on my washer
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
The washer stops before rinseing and sends a code 5D.
Hi
Daniel
Aug 23, 2011 | Kenmore HE2 Plus Front Load Washer
The machine had an F in the display window and now I can not open the door - it's locked!
Most probably what is happening is that your washer isn't draining out the water so yhe door stays locked.
Easiest thing to do is open up your bottom panel by taking three screws off
then you tilt washer on a 45degree angle and have a couple of towels close by
unscrew cap on front of drain pompe and you will probably find some foreign objects or if not probably drain pump defective.
But before doing all this put washer in a drain spin cycle and if you hear a weird humming sound its a good indicatio that you will be performing what i suggested above
Jun 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Display says sd
Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 27, 2011 | Kenmore HE2 Plus Front Load Washer
What does it mean when the display comes up as sd
Hi
Error code SD or 5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Daniel
Jan 25, 2011 | Kenmore HE2 Plus Front Load Washer
Sd error display. Not slow draining
Hi
Daniel
Dec 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washer displays the f21 error code. it did this once before and i had to take the bottom front panel door off to get to a the problem . i can not remember how to get this panel off. can you please...
Hi
Daniel
Dec 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My TB 1000w does not drain & the pump seems to be working
Check first drain hose at the back. If that is fine, next step is disconnection appliance from power and reaching the drain pump. Even if the pump is working there may still be a blockage in hose connected to pump. Pump is accessed removing the small panel on the lower right side , in front of the appliance. Be prepared to collect a lot of water with a pan when you undo the pump.
A blockage in pump is the most common cause for drain problem, however, if there is no problem on pump lines, problem with pressure switch/water level and timer board can also cause the washer not draining.
Accessing the drain pump and cleaning the hoses will probably fix the problem
Oct 10, 2009 | Tricity Bendix AW1000W Front Load Washer
Kenmore Elite HE3t- suds-
advance machine to drain/spin cyce to remove the water.if it doenst drain and just "humms". try removing the lower access panel. just behind it youll find the pump assy unscrew the face and empty the contents (probably lint, baby bock, assorted stuff from pockets)be prpared though the hose above is FILLED with water. Make sure your using HE detergent!!!!!!!!!!
Mar 08, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
