Question about Keurig Platinum B70 Coffee Maker
Keurig 70 making large hole top k-cup seems to be not closing properly. When I close the top it goes about half way and then sticks. If you force it you get the big hole and puff out of grounds making the whole machine a mess. Then need to clean with paperclips. If I press back on left hinge or push bottom basket forward towards machine, closes properly and seems to be ok then.
SOURCE: Not Brewing
We have had this problem intermittently but we had a bigger problem that I solved yesterday. Our LCD display was not displaying properly - words were missing so we just had to guess when it was ready to brew. I called Keurig and they offered a new one for $100 since it was out of warranty. They did ask me if I had descaled the machine and, I'm embarassed to say, I had never done that. Well I descaled the machine and viola! - my LCD display completely came back just like new! Here's hoping the intermittent brewing problem is resolved as well! If you haven't descaled the machine recently, I would strongly suggest giving that a try for any problems you might be having. Of course, to descale, the machine has to at least be able to brew in order to get the vinegar through the machine...
Posted on Apr 04, 2008
SOURCE: Keurig machine releasing coffee grounds on top of K cups
I have the same problem but if you take a paper towel and clean the grounds from the top each time it helps. Cleaning around the little point that pierces the cup. It helps but doesn't completely eliminate the problem.
Posted on May 19, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: My Keurig just started only filling my mug 1/2
Have you tried following the descaling procedure given in your owner's manual? The mineral build-up from hard water can cause low flow, and since the machine pumps for a fixed time this means less water in the cup. Descaling usually brings back normal operation.
Posted on Mar 06, 2010
cmccune04
  • 213 Answers
SOURCE: Need Keurig B3000 Cups & Pivots
http://iwantsweetdeals.com/Keurig-B30-B40-B50-B60-B66-B70-B77-Replacement-K-cup-Holder-Assembly-Part-J-P1208231.aspx
These will fit your model without a problem
Hope this helps you!
Posted on May 26, 2010
cmccune04
  • 213 Answers
SOURCE: Keurig replacement part
http://iwantsweetdeals.com/Top-Needle-and-Seal-Replacement-Part-Used-for-B40-B50-B60-B66-B70-B77-Brewers-P1227669.aspx
This is the whole assembly I hope this helps you!
How do I get it to close properly,so that it can brew???
I have this issue with one of my Keuring machines also. I find that if I push in on the k-cup holder while pulling the top down the problem goes away. Try it and see if this works for you too.
Aug 31, 2016 | Keurig Elite B40 Coffee Maker
Why does my Keurig smoke when brewing coffee, and the water doesn't go through until I take out the cup?
You probably have a clogged nozzle/needle. Take a straightened paperclip and run it thru the hollow needles that puncture the top and bottom of the k-cup. Make sure they are clear then try to brew a cup. Never reuse a k-cup. That's what usually clogs the needles.
Sep 19, 2014 | Keurig Coffee Makers & Espresso Machines
The keurig wont stay on
Contact Keurig. They are great about replacing them. They usually only ask for the cup dispenser and will send you a new one
Oct 15, 2013 | Coffee Makers & Espresso Machines
My k cup reusable coffee filter for the b60 keurig coffee maker is leaking water when i'm brewing coffee with it. What should I do to fix this?
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Dec 29, 2010 | Keurig B60 Coffee Maker
Size Cup Malfunctioning
you might want to descale it with vinegar at least a few times.
Jul 10, 2017 | Keurig B60 Coffee Maker
Where can I buy parts for this coffee maker
mcdevito75 here, You can check online, just type in Keurig Ultra 850 and see about replacement parts. May be cheaper to replace coffee maker.
Jun 20, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
When making a cup of coffee, half the water flows back thru the vent resulting in half a cup of coffee. I have de-scaled but that did not fix. Any suggestions?
When the water comes back through the vent, it usually means that the TOP needle may be plugged with coffee grounds.
Unplug the coffee maker.
Lift up on the silver handle, and look inside. You will see a silver needle (similar to the one in the bottom of the K-cup holder). With a round seal surrounding it.
Straighten out a paper clip and run the clip through the center of the needle, and rotate it, then pull the clip out.
Plug the unit back in, and wait until it is ready.
Remove the K-cup holder, and run only water through the unit, as if you are making a cup of coffee.
You will see some grounds in the coffee cup, if the needle was plugged with grounds.
If this doesn't fix it, call customer service, the unit may be bad.
Jun 02, 2010 | Keurig B60 Coffee Maker
Just bought a cedo rue soft close. any idea of order of washers going on etc as instructions unreadable
Metal peg fixing goes "into" large plastic "cup" washer. Metal fixing now goes through holes in toilet pan sitting in the "cup" washer. From the bottom push up the thin round plastic washer, convex side towards the hole. Next the oval shaped thick washer flat side towards the hole. This has a cup shape into which the final plastic screw fitting pushes into (like a coax plug on the TV aerial). This will push up the thread into the cup where the sides force the thread to grip. Finger tighten so that you can still move the metal fixings from the top. Line up the toilet seat holes and push fit onto the pegs. It may take a smart thump to get them fully seated. Before tightening with the supplied black plastic spanner" make sure the large "cup" washer on top has not got trapped under the metal fixing. If all is ok line up the seat and tighten.
Dec 24, 2009 | Home
Keurig Platinum B70 Coffee Maker Logo
618 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
