Question about Speed Queen Washing Machines
Machine starts to fill up with water but does not stop filling so cycle for washing does not start. Water then overflows out of machine
    Problem Solver:
  • 9 Answers
Sounds like faulty pressure switch
Posted on Apr 03, 2011
  • 1028 Answers
SOURCE: Our washing machine keeps filling
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Posted on Apr 27, 2008
Washer_tech
  • 164 Answers
SOURCE: Maytag Washing Machine - water will not shut off and overflows tub
this could be either a bad pressure switch, located behind the control panel. it has a small usually black hose running down to the tub. more than likely since this is an older machine the hose has become worn in one spot and is leaking air. replace the hose and that shold do it. if not its the presasure switch.
Posted on Nov 29, 2007
Illeagle
  • 525 Answers
SOURCE: Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
Posted on May 24, 2008
SOURCE: Filling With Water
I recently had the same problem. I checked the end of the air hose coming from the tub. It had a tear in it right at the connection. I just cut off the hose at the tear and placed the hose back on the connection.
Posted on Jul 18, 2008
  • 958 Answers
SOURCE: fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Dec 30, 2012 | Whirlpool Washing Machines
Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
Machine does not stop filling with water. Will
Sep 30, 2009 | Washing Machines
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Fill will not stop
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
May 20, 2008 | Maytag Performa PAV2200
Washing Machines Logo
139 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
