Question about LG Flatron L1515S 15" LCD Monitor
Monitor won't light up. Only just for a second or two.
Hello!
I have three LG Flatron L1515S 15" LCD monitors with the exact same problem.
At startup they just light up for a second or two and then goes dark. BUT! The monitors are still working. I can still see the image but very very dark. It's like the "lamp" behind the screen only starts up only to shut down again. If I switch it off and on again - the same result. Perfect picture for about a second or two.
Everything seems to work except the "backlight" won't stay lit.
Is this a known problem and is sit possible to fix fairly easy. I'm quite familiar with electronics and soldering, but I would like som help finding the faulty components.
  • 2 more comments
  • Anonymous Aug 09, 2008
    I have the same problem. The flat screen lights up for just a couple of seconds then it goes dark, but I can still see the desktop faintly. Mine is an Optiquest Q9
  • Anonymous Oct 19, 2008
    I have the same problem. The flat screen lights up for just a couple of seconds then it goes dark.
  • Anonymous Jan 06, 2009
    I have the same problem. I have an Optiquest Q9. How can I fix it, without spending a fortune. I can not afford right now to buy a new monitor.
  • onechrisw Apr 01, 2009
    I have the same problem, changed ALL the caps, even swapped entire power supply unit with another from a working unit, no help
  • 790 Answers
Hi
this issue is made by defective torch or lamp at the back of LCD...
Thanks!
Posted on Mar 06, 2009
  • carlos fernandez Jr.
    carlos fernandez Jr. Mar 06, 2009
    replace the ballast circuit of the lamp to get light lamp
    tHnak!
  • 22 Answers
Try to check the capacitors and or replace it.
Posted on Jan 08, 2009
Lg 15"lcd screen broken
Much more cost effective to replace it.
Nov 21, 2012 | LG Flatron L1515S 15" LCD Monitor
I need the drivers of flatron w1943tb....
LG Flatron L1515S doesn't need a driver to be installed on Windows Computer or any other systems. If you have problem with it, then it should be your graphics driver that you would need to install.
Similarly W1943TB-PF doesn't need driver. (I am not sure which one among the two LG Flatrons you have since your question is tagged under the LG Flatron L1515S while your problem refers to LG Flatron W1943TB.
If you have other problem, let me know with more details.
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | LG Flatron L1515S 15" LCD Monitor
LG Flatron l1515s which is giving Out of Range 64.0kHz / 60Hz and can not even give setup menu. Please help.
This is not a setting on your monitor. It is a setting on your operating system. The display settings needs to be set to a 60Hz refresh rate.
Hook up your old monitor and right click on desktop --> properties --> and then to display and advanced settings. You can then set it to proper refresh rate and plug the new monitor in.
Mar 28, 2011 | LG Flatron L1515S 15" LCD Monitor
My LG e2350 monitor won't turn on. When I push on the power button, nothing happens except that one of the light on the left lights up.
there's a button on the far left, that which when you press should light up the power LED. i know it's weird, but it does that.
just hold that for a period of i don't know how long, maybe 10 seconds til the power LED goes off. wait a while, then press the power button again. that worked for my friend's monitor that had teh exact same problem as yours.
you probably fiddled with the menu buttons before this. and pressed the "input" setting.
Dec 19, 2010 | LG Flatron L1515S 15" LCD Monitor
Omi have lg flatron 1941s lcd monitor its OSD locked how to solve it
i have a problem with my lcd a small area is permanently black a scratch like lines less than 4 mm X3 mm size
Sep 17, 2010 | LG Flatron L1515S 15" LCD Monitor
LG Flatron L1515S 15" LCD Monitor Problems & Solutions
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | LG Flatron L1515S 15" LCD Monitor
Power ON, no display ,when switch off and on screen display for 1 or 2 second, again goes blank. model= LG Flatron -L1515s
check the power cords and the video connectors. if it's ok, then it could be a problem on video card
Feb 17, 2010 | LG Flatron L1515S 15" LCD Monitor
monitor display center line problem
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
LG Flatron L1515S 15" LCD Monitor Logo
752 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
