Question about Akai Televison & Video
I have an Akai tv, model KC09-b2. The tv shuts itself off after 4-5 minutes of it being on but only when i am watching tv through a digital box (motorla DCT6416 III). the sleep function is set to off.
    Scholar:
  • 67 Answers
While this suggests a power supply problem with the tv, the digital cable box should really have no bearing on the shutdown. The cable box only sends audio and video signals at an extremely low voltage to the main board. The issue is with the power supply. You might want to take the back of the tv off and see if there are any puffed up capacitors on the power supply pcb. This is the board where the power cord plugs into. If they are puffed, replace the capacitors with an equal or slightly higher value. The values are in mfd and voltage which are printed on the capacitors themselves. Keep me informed. Thank you
Posted on Apr 03, 2011
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
Keeps cutting off while watching tv
If the set shuts off then tries to turn itself back on then I suspect the lamp. The lamp part number is BP96-01472A. If it just shuts down and then you are able to turn it back on, then in most cases you have a bad digital board. The part number for the main/digital board is BP94-02262D...Please take a few moments to rate my answer. Thanks...
Nov 24, 2009 | Akai PT50DL24 Television
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Is my akai projection tv digital ready or do i need to purchase a converter box.
depends if you have a cable service. Cable companies will still broadcast in analog because they are a closed system same with sat. only other way to tell if you have a digital tuner is by one a cable/satalite card or when doing the tv programing it asks digital?
Apr 14, 2009 | Akai PT4298HD Rear Projection Television
Akai TV troubleshooting
Click here to find the power box for your TV. I would suggest to contact them first with the proper model of your power box before buying it.
Feb 16, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Need setup codes for Akai KC01-B2 to run with comcast remote
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Dec 27, 2008 | Akai LCT2785TA 27 in. LCD Television
I have a AKAI CFTD 2085 model tv. Is it digital or do I need a converter box?
If connected to cable or satellite your tv will work after digital conversion occurs. If using an antenna, look up a local TV station to see if they're already broadcasting in digital. Most are. Enter that DIGITAL channel # using your remote. If you get a picture, you don't need a converter box.
Dec 04, 2008 | Akai CFTD2085V 20" TV/VCR/DVD
I have an Akai 42"lct & had the same problem. I bought an universal remote URC R6 at walmart for $19. I can now control the tv, u-vrerse cable, panasonic surround system & still have the aux open. You must use the "learn" method but I can control channels, volume, record, menues for all devices as well as setup, record for dvr & more. I hope this helps.........
Jan 29, 2008 | Akai CF2791 27" TV
Plasma TV - won't turn on
well, there is no fuse box. it's a small, 20mm fuse, tere is one on each board. just remember what screws you take off where. take pics along the way, draw yourself notes. inside it's like home computer, just boards and screws. probably fuse or the power supply board itself.
Jan 08, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Televison & Video Logo
43 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
