Question about Sewing Machines
I have a 1030 Bernina sewing machine and for the first time in 10 years the needle will not move up and down. It will go side to side. It stopped while sewing and won't restart. I have checked all of the common troubleshooting things on the machine and none of them worked. Please, can you help me? Thanks,Tania
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
There is likely a frozen linkage on needle bar that requires servicing to free it up take it to your Bernina dealer for full service
Posted on Apr 01, 2015
  • Sewing Machines Master
  • 9,546 Answers
Have you tried cleaning and oiling your machine? Refer to your owner's manual and use good quality sewing machine oil, ie Bernina oil for mechanical machines.
Posted on Feb 24, 2015
    Genius:
  • 1,788 Answers
Take it to your Bernina dealer, they should be able to determine what is wrong and hopefully fix it, free. You really do not want to do something that could void your warranty. My Bernina dealer is super nice and always helpful, they are very professional. I hope that it is just some silly thing, like mine was.
Posted on Apr 04, 2011
I have a Bernina Patchwork 140. How do I change the needle to stop in the down position? The sewing manual is no help.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The manual for the Patchwork 140 is available at Manuals Lib here: https://www.manualslib.com/manual/1002243/Bernina-Activa-131.html . The Bernina 135 has the needle stop up/down button. See https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-135 . The manual for this model is https://www.bernina.com/getdoc/90f75840-2b12-4f46-88f2-76f09e35d8d4/030529-52-04_0303_a135-a145_EN .
I hope this helps.
Jul 31, 2017 | Bernina Sewing Machines
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Wheel on right side that controls the needle up and down is very tight...
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
How can I take the back of my bernina 1030?
Bernina 1030 Service Manual Page 5
If you click the tiny page pictures on this page they expand. Page 5 discusses taking off the back.
Jun 17, 2017 | Bernina Sewing Machines
Needle keeps breaking when quilting
the machine needs to be taken to a sewing machine shop & be
checked to see if it has jumped time,, a sewing machine shop
technican has the tools to retime the machine & the foot needs
to be filed to get rid of the burr on it.
Aug 11, 2012 | Bernina Artista 180
Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced.  This is a simple fix and it happens all the time on those machines.  Take it to your local Bernina dealer for a standard service.  Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
Sep 16, 2007 | Sewing Machines
Sewing Machines Logo
207 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
