Question about Maytag SkyBox MBV1976A Beverage Dispenser
I think I have a bad thermostat control in my Maytag Skybox. Where can I find a replacement?
    Habit-Forming:
    New Friend:
  • 25 Answers
Maytag parts.com Part number 11001070
Posted on Jul 17, 2013
  • Michael Laythorpe
    Michael Laythorpe Aug 18, 2013
    where do the wires connect to the thermostat? I have a new item and the old wires were moved before noting what connection they go to.....Please help....
Master_Tech
  • 770 Answers
SOURCE: Maytag SkyBox
Both Check your emails
Posted on Apr 28, 2008
SOURCE: maytag skybox schematic
there is a basic schematic on the back of the unit
Posted on Apr 30, 2008
  • 90 Answers
SOURCE: Maytag skybox start relay is bad
you need to change the overload relay ---- there is a company called appliancezone.com
they sell the overload relay unit with all the parts for $26.00
email me back if you cant find it---- put in the model # for the skybox unit and you will see the item
item # 4387835
this is the problem -- if this relay goes bad the compressor will stay on and not supply cold air to the unit ----
Posted on Dec 30, 2008
SOURCE: removing compressor from maytag skybox machine
Maytag never offered a compressor as a replacement part for the SkyBox. It simply was not cost effective. If you are sure the thermostat is supplying 120VAC to the compressor, then have a qualified service technician install a Supco URCO410 relay/capacitor/overload kit on the compressor. As with any sealed refrigeration system, the US Environmental Protection Agency requires that a certified refrigeration technician recover the refrigerant charge before accessing the sealed system.
I hope this helped.
Posted on Apr 25, 2009
SOURCE: Replacement for Skybox compressor
The solution is too change refrigertants, Enbraco makes the PW4.5hk11. its a little over sized and you'll need to switch to hot shot.
Posted on Jan 29, 2010
Where is the fan located?
The fan is located behind the bin dispenser assembly. It is a low voltage fan, and runs as soon as the SkyBox is plugged in. The thermostat controls only the compressor.
Jul 17, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
My Matag Skybox compressor will not turn on. I can here it clicking and trying to come on.
HI. This is a strong indication of starter/overload relay failure. This clicking noise is coming directly fromm the relay device. it is damaged. this relay is the main starter of the compressor unit. It receives a signal from the main PCB. Once the power signal is received, the relay will regulate the starting, and stopping of the compressor, via control board and thermostat assembly. The failed relay will need to be replaced, asap. Once replaced, the unit will operate correctly. The relay is mounted on the side of the compressor. Once the bracket, and terminal wires are removed, you can gently pull it away form the compressor, to check the contacts and connections for corrosion. If any of the contacts or terminal connections are worn, replace them. Worn contacts, or corroded connections will not allow for proper current flow.
NOTE_ I would advise to locate the clicking. Make sure its coming form the compressor/relay location. There are some units of this nature out there that are fixed(compressor and relay intergraion). If this is the case, simply replace the entire compressor unit. If the clickiong is coming from the main control board(PCB), the PCB, will be the culprit.
Dec 01, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox is freezing and making a humming noice.
The temperature in the SkyBox is controlled by the thermostat located within the beverage compartment. If set too high, product can feeze. In addition ice will build up behind the dispenser assembly. The ice buildup can eventually make contact with the circulating fan blade and cause a constant noise.
You should hear the compressor stop running as you turn down the cold control, but prior to reaching the "off" position. Select a lower setting for the cold control, and unplug the unit for 24 hours with door open to thaw out the ice build up. Reconnect power to resume normal operation.
Apr 04, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from maytag skybox machine
I hope this helped.
Maytag Skybox stays at 50 degrees all the time
The SkyBox was built for Maytag by a company in China. Production stoppedabout 2 1/2 years ago, and Maytag purchased ALL available service parts available at that time. As inventories are depleted, there will be no more parts available.
An issue with the SkyBox involved a build up of frost and ice on the evaporator plate built into the wall behind the dispensor assembly. This build up insulated the product from the evaporator coil. It also caused the circulation fan to stop running. Unplug the unit and leave the door open for 24 hours. Plug it back in, set the thermostat indicator at the 11:00 position and close the door. See if this brings the temps back down to the 36 to 42 degree range, I hope this helps.
Jan 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
item # 4387835
Dec 16, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Manual
Request the service manual from Maytag.
Oct 29, 2017 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox-2 problems
maybe bad fans and a dispenser motor post your email and iwill send you the svc manul so we can look into it deeper
Mar 03, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
129 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
