Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
I have a Dirt Devil Reaction D2 Dual cyclonic Technology upright vacuum. The power head (beater bar) will not turn. The belt is fine and on tight. The bar turns freely when I turn it manually. I have cleaned the hair and junk from the beater bar, turned it freely, but when I turn on the vacuum - it does not turn.... I thought there may be a reset button, but I can't find one. Any ideas??
  • Handie Andie
    Handie Andie Apr 03, 2011
    If the beater bar doesn't turn, generally the problem is with the belt. Did you turn the vacuum on its side to see if the belt actually turns when the motor is on?
    Handie Andie
  • sedwards680 Apr 03, 2011
    NO - The belt is not turning
  • 710 Answers
If the belt does not turn, perhaps you have it on too tight? Just a thought.
Check to see if you can turn the belt by hand. Look for any debris that might be caught in the belt mechanisms. If nothing like these things are the problem, it could be in the drive mechanisms.
Here is a website for your model with a parts breakdown: http://www.dirtdevil.com/manuals/?id=fb85c19d-2fbf-47bc-b8f6-ddc128067314
I hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Posted on Apr 03, 2011
Bush roller squelling on dirt devil 130005 upright bagless cyclonic vacum
My dirt devil has 3 screws underneath- these are the same ones you use to change the belt--sounds like something is caught in roller-- mone was full of hair!
Jan 02, 2014 | Dirt Devil M130000 ''i'' Dual Cyclonic...
I have cleaned the canister, the filter, everything....and yet the dual blades won't turn and there is barely any suction. HELP?
the suction part must be a clog in between the suction port into the unit check that and if they dont turn maybe belt broke or something is stuck
Feb 15, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
We replaced the belt after about 5 uses, and now every once in a while it smells like burning rubber, I checked to belt to make sure it was ok, and then last week it started smoking. Is there reported...
If the belt is hot or burning during use, it could be due to a beater brush, which the belt drives, being bound up in some manner. The beater brush is removed during belt changes and should be cleaned of all debris as best you can. At each end of the beater brush there is a plastic clip of sorts that holds it in the vacuum. Spray some WD40 between the bar and the plastic clips then rotate the clips to be sure they move freely. Reassemble with a new belt and put it to use.
If you find this solution to be of help to you I would appreciate a Thumbs UP rating. Paul
Oct 09, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Our Dirt Devil D2 bottom has no suction
I would check the bottom of the unit to see if there is any blockage. I don't know if this unit has a switch that you set to switch from hose to floor. If so I would set it to floor and see if there is any suction in the hose, indicating a switching problem. If there is no suction in the hose, I would still check the bottom of the unit and disassemble it as much as you feel comfortable to see if you can see any blockage. Good luck!
Mar 13, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Vacuum doesn't work on bare floors!
does it have a bare floor setting that shuts off the beater bar? if the brush is revolving it will scatter dirt instead of picking it up
Aug 23, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
No clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Canister
The filters are not clean on both sides. Check the main filter at the top and the internal filters for each side, clear and brush cleanly and gently to remove all clogged dirt as well as checking the hose and inspection airways i.e. when the bin is taken off check the holes behind it and behind the beater bar for any clogging material.
Mar 02, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Dirt Devil Reaction Dual Cyclonic- M110000, "cyclones" not spinni
If the filters have been washed and installed back in instantly there wont be any suction. Check the top filters have been cleaned thoroughly and also check inspection tubes/hose and dust channels to check for a clog. Also check the sole plate / bottom of where the beater bar as there may be a clog somewhere.
Jan 15, 2009 | Dirt Devil M110000 Bagless Upright...
Brush on/off lever
Replacing a belt or how to get into the vacuum cleaner . It is a Dirt devil Reaction D2
Oct 09, 2007 | Dirt Devil M1100009 Reaction Soft Touch...
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
423 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
