Question about Char-Broil Grilling
How do youremove and replace a charbroil gas grill burner on model number 463268007
    Brigadier General:
  • 4,736 Answers
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Posted on Apr 03, 2011
#4635102 need new burner
The 4635102 model number is not a Charbroil Model Number. However, 4651330003 is accurate. And burners are available for it from Charbroil http://www.charbroil.com/Parts/529/2002--2003-Charbroil-Gas-Grills.aspx
If that doesn't work for you. You can use the same link to find one for your grill. But, you must have the correct Model Number.
Hope this helped you. Happy Grilling!!
Jul 14, 2011 | Char-Broil 465133003 Grill
How do you replace the burner its clogged and rusty
You can order new burners straight from the manufact website. Lowes carries the simple two burner or one burner units. It depends what model you have as to how you install it. Most are easy and are screwed down with phillps head screws. If you have the model I can go into more detail.
Jul 01, 2010 | Char-Broil CharBroil Master Flame Gas...
Where can I buy Charboil BBQ spares in the UK, in particular a burner for a Charbroil 200?
The email address sales@charbroil.co.uk does not work. I get a mail delivery failure. I have searched many times for a UK supplier and cannot find one.
Apr 11, 2010 | Char-Broil CharBroil Master Flame Gas...
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
How do I get the gas burner off so I can see the ignitor?
Turn off the gas at the tank. Remove the main grille wire. Looking up from the back you should see one clip on each venturi, these hold the burner on the tubes. Note the placement of the clips, to ease replacement.
The clips hook on both ends.
Remove both clips and carefully slide the burner toward the back and lift out. There's quite a jolt if you touch the ignitor while striking. Good luck. see link for charbroil replacement parts. http://www.charbroil.com/Consumer/ReplacementParts.aspx?ProductID=461
Jul 05, 2009 | Char-Broil Quickset Traditional 463761006...
Flame Shooting out the front
You clearly have a gas leak. Inspect the suspect area for loose connections like the gas delivery pipe to the burner assembly. Try to reconnect them. If there is a hole in it you can use some muffler repair adhesive but I would just get a new part. Often the company will send you free parts as a good gesture to assure encourage repeat business. Check out the links below. The second one offers free shipping.
www.charbroil.com/CharBroilWarranty
www.clagrills.com/grillparts/charbroil/charbroil-grill-parts-home.htm
Jun 20, 2009 | Char-Broil CharBroil Master Flame Gas...
Replacement of gas burners
Hello, The model number that you gave is relatively simple to change the burners.
  1. Remove the 3 cooking grids
  2. Remove the 3 vaporizer tents
  3. Between each burner is a "pal nut" that just pushes on and will likely be destroyed when you remove it. They run a couple bucks each at Sears, part # 7000132
  4. This will release the carry over tube holding the burners down and the burners can be lifted out.
  5. Ensure that you clean out the carry over tube when you reassemble. This carries the flame from the first burner across to each of the rest of the burners when lighting them.
  6. Reassemble in the reverse order ensuring that you put the burner tubes over the burner valve tubes when reassembling.
You can find a parts listing with the parts numbers at: http://www.charbroil.com/Parts/80/Performance-Series.aspx
If this was helpful, please vote yes. Thank You!!
May 29, 2009 | Char-Broil Advantage 463453306
Only one of four burners will light.
Hello, there is a carry over tube between the burners that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000280. They can be purchased directly from Char-Broil or Sears parts.
http://www.searspartsdirect.com
If you find this helpful please vote yes. Thank You!!
Apr 19, 2009 | Char-Broil Advantage 463453306
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
Grilling Logo
315 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
