The wiring diagram just lists the connections as #1, #2, & #3, it does not tell me what to connect to them. what i need is, example: hook #1 terminal to the green (ground wire). Can you tell me what wires hook to each terminal? ps. the centronics ar-500xl is an outdoor tv antenna rotor
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
gotgeek2
  • 565 Answers
SOURCE: Need wiring diagram for Intermatic 240V Mechanical Time Switch
For anyone else who may be reading this post, these instructions are for the T104 ONLY.
Connect your incoming line) 240 volt wires to terminals #1 and 3. Connect the outgoing 240 volt (load) wires to terminals # 2 and 4. Don't forget to connect both equipment ground wires (bare or green) to the "GR" terminal.
Do NOT connect anything to the "A" terminal.
Posted on May 09, 2009
smarthome2
  • 1114 Answers
SOURCE: Outdoor speaker hook-up
Go into the manual setup on the GUI then go to the zone 2 and zone 3 setup. If you are using only the power from the receiver to power the speakers, make sure the setting is for Zone 3 amp "INT" if you still have no volume, on the front of the receiver look at the display, make sure "zone 3" is lit up then use the small remote and turn up the vol. if it's on you will see "zone 3 vol" and the bar going up it should be ok. if it says "fixed" it thinks you have an external volume control, if you do, make sure it's "on" at about 12 o'clock and test. If not, you need to switch it in the on screen "menu" or "GUI" button, follow to zone 2 & 3 vol control and make sure it is set to variable. If you still have no vol post a comment and we can dig further. Hope this helps
Posted on Jun 06, 2009
  • 50 Answers
SOURCE: need to connect an indoor FM antenna to the
the indoor antenna you have must have a screw on connector and the receiver has a smooth connector or you would already have it hooked up. Go to Radio Shack and buy a connector that turns the coax into a slip on style.
Posted on Aug 14, 2009
smarthome2
  • 1114 Answers
SOURCE: Hooking up Kenwood AR-304 to LG TV
You need to connect the TV "Monitor Output" which will be standard audio (RCA) red and white. Then you need to make sure you go into the TV's main menu and go thru "Audio". You may need to turn off the TV's internal speakers to get output via the RCA monitor out. If by chance it has a setting for "Fixed or Variable" for the output, select "Fixed" and control the volume thru the receivers volume control. If you still need further help, don't hesistate to ask! I can walk you thru it. Hope this helps
Posted on Aug 19, 2009
I need to wire up a 3 phase compresser motor, 9 wires wired 480, to change to 240 volt hookup. right now it is wired 3 motor wires to each hot, no nameplate or wiring diagram.
Please verify the existing connections to determine if they fit the "High Voltage" configuration listed below. If they do (and they should), the "Low Voltage" configuration below is then correct for 240.
Jaypug
Low voltage ...
L1---1--6--7
L2---2--4--8
L3---3--5--9
High voltage ...
L1---1 4--7
L2---2 5--8
L3---3 6--9
Dec 04, 2013 | Gb Electrical 100 Amp GE Load Center
How to hook up 14-3 wire to the panel
Following wiring diagram is for general purpose household 120V-240Volt service.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-10-1000.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/Color-codewire.html
Why are you asking that question without saying what you are wiring? 120Volt, 277V, 480V etc?
What does rating plate say on device you are connected to 14-3 wire?
And what amp/volt/watt rating are you connecting to 14 gauge wire?
No electrician would omit that information.
14-3 wire is usually only for 3-way switches and other light duty applications.
Must be connected to 15 amp breaker and no larger.
Apr 08, 2013 | Electrical Supplies
How do you hookup a universal hvac condeser motor the old one had a black wire,red and a brown wire plus the green&yellow ground the new one has a black wire a yellow then it has back connetor thats...
WHAT??? Did the new motor come with a wiring diagram? Typically you will either be using a "3 wire" connection or a "4 wire" connection. 3 wire is for using the existing capacitor (provided it's the right size), 4 wire is for using a separate capacitor. You should have 5 total wires on new motor HIGH/LOW/COMMON/CAP & CAP. Then possibly some separate wires for ground and rotation. The ground goes right where you mount the motor, rotation...make sure its blown up and out of the machine. 3 wires would be...1 SPEED 1 COMMON 1 CAP. 4 wire would be 1 SPEED 1 COMMON 2 CAPACITOR WIRES. Good Luck!!
Apr 10, 2017 | Heating & Cooling
Need wiring diagram for T104M 208-277v Mech. Time Time Switch
Here is the basic instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Below is a larger and better diagram of a 240V connection Terminal connections are White to White on 3 & 4 Black to Black on 1 & 2:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
More info: http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
I am assuming you have the 240 VAC clock motor so the clock timer motor wires are connected to terminals 1 and 3.
If you only have the 120 VAC clock motor the wires will be connected across terminals 1 and 2.
Thanks for choosing FixYa,
Kelly
Jun 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
What order do the connections from numbers 1 to 6 go when connected to the coil pack ? e.g. 1 & 2 go to 1 & 2 of first coil 3 & 4 go to 3 & 2 of second coil 5 & 6 go...
TELL ME TYPE CAR MODEL AND YEAR OF THE CAR I NEED TO KNOW ALL YOUR ENGINE INFORMATION BEFORE I CAN TELL YOU COIL PACK PLUG WIRES LOCATION.
Apr 04, 2011 | Isuzu VehiCROSS Cars & Trucks
I need a wire diagram for a high voltage Baldor motor CAT # 054180 79151 connect to 440VAC it's a 40HP, RPM 3525 , 3PH and it's SPEC# 40F97Z22 please help
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7 Connect #5 to #8 Connect #6 to #9
Connect supply phase A to #1 Connect supply phase B to #2 Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
Aug 05, 2010 | Gb Electrical 100 Amp GE Load Center
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Help on 1 amp and 1 alpine srw-124d
You have dual 4-ohm coils. 2 coils per speaker.using one speaker, if you take and run the postive from one coil and connect it to the negative of the other coil, then take a wire from your bridge channel on your amp and connect the positive to the the remaining positive on the one coil and connect the negative to the remaining negative on the other coil you will create a 8ohm load on the amp in bridged mode.
now this is the important part. The bigger the load on the amp the greater the wattage output to the speakers. This sucks the wattage out of the amp. Careful not to overload you amp. The setup above is safe for any amp. The following is for 2ohm stable amps only. The lower the ohm value 2, 4, 8 and so on, the greater the load on the amp.
connect the positive of one coil to the positive of the other. connect the negative of one coil to the other negative of the other coil. then take a wire from your bridge channel on your amp and connect the positive to the the positive on one coil and connect the negative to the negative on the same coil and you will create a 2ohm load on the amp in bridged mode.
Series = add the two ohm value
parallel= halve the ohm value
you can play with series and parallel together using more than one speaker setup.
Jun 07, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
41 people viewed this question
 Grubhead
Grubhead
