Question about Black & Decker Garden
My black and decker st6000 is not popping out the string to edge it is a touch feed when popping to start it won't bring out the string HELP!
  • 710 Answers
I have a touch feed trimmer also. I've found that when the string doesn't come out, there is usually a twist in the line inside on the bobbin. Open it up and see if the line needs to be straightened out. Sometimes I've had to rewind for a bit.
Before you do that, be sure you are bumping it hard enough. Mine needs to bumped on a pretty solid surface.
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Posted on Apr 03, 2011
Where can I download black & decker st6000 owners manual
Couldn't find one. Might this one serve?
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0CDIQFjACahUKEwi3s7mfpIvGAhVRMowKHbmUAP0&url=http%3A%2F%2Fwww.ehow.com%2Fhow_7484314_thread-black-decker-st6000.html&ei=wWd7VffOFtHksAS5qYLoDw&usg=AFQjCNFL3IyFWdUOOtb62OxVuFd6dzbi7Q&sig2=mPBwzo9n_QxBGoVh_P5efg&bvm=bv.95515949,d.cWc
Jun 12, 2015 | Black & Decker Garden
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Broken Edge Guide
The diameter of the Black&Decker GH400 edge guide is 1/8". I know because I have the same problem and a small piece left from the original. Trying to find a new one is quite the quest.
Apr 22, 2010 | Black & Decker Garden
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
How do I add new string to my black and decker st6000
Home Depot have the string for the black and decker weed eater
Aug 25, 2009 | Black & Decker String Trimmer Cordless 12"...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
How do I get my Black and Decker 12"bump feed trimmer/edger out of the groom position and into the edge position? My boyfriend misplaced the instructions to our new edger and I can't figure it out.
The handle/shaft is in two parts. By grasping the upper part of the shaft with one hand, and the lower part with the other, you can move the two sections slightly apart, then twist to turn the trimming end 180-degrees.
Sep 15, 2008 | Black & Decker String Trimmer Cordless 12"...
How to feed line into a black and decker trimer/edger model st6000 electric?
The ST6000 uses centrifugal force. Once you mount the new spool of string and thread it out of the feeder and into the housing below, plug it in, give it power and hold the line feed button down, feeding the line. Within seconds, the line will feed out through the head and you'll be in business.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
Corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Garden Logo
253 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
