Question about Coffee Makers & Espresso Machines
My keurig b30 wont fill up my coffee cup. makes brewing sounds but nothing comes out
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 08, 2011
No water will come thru the coffee. It heats up but doesn t brew
heatman101
Jul 24, 2011 | Keurig B30 Mini Coffee Maker
Keurig coffee maker isnt working--water brews turns red but does not come out--1/3 cup
heatman101
May 21, 2011 | Keurig B30 Mini Coffee Maker
I turn the machine on, add the kcup and water...lights blink but nothing brews, then turns itself off...B30 unit; please advise Thanks
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
May 16, 2011 | Keurig B30 Mini Coffee Maker
All the water is not going through when I make a cup of coffee. It only makes about l/4 of a cup
Problem:
Keurig B30 would only brew a partial cup and stop. Had to run 3 times to complete brewing.
Solution:
With the coffee maker unplugged and an empty cup in place, I filled the reservoir with filtered water and with a short length of flexible plastic tubing I blew in to the small hole in the bottom of the reservoir. I did this 4 or 5 times sucking some water in to the tube to force it through the system. When I had finished there were a lot of grounds in the cup and the next time I used the coffee maker it worked perfectly.
Apr 17, 2011 | Keurig B30 Mini Coffee Maker
(B30 mini) no water comes out... we have had it for 3 weeks, I have cleaned the needle... and the funnel. Everything goes as normal, the water heats until it is time for the coffee to come out- then the...
So I had this same problem the fix was pretty simple. Air had gotten into the fill line and the pump couldn't pump the air filled line. So to get rid of the air try to brew a cup of coffee (make sure you have a cup under) now cover the over flow at the top of your water reservoir with your finger or thumb. Air bubbles should blow into you water storage tank. Once the bubbles are gone remove your thumb or finger. Now try to brew a cup of coffee again.
--snapshot4
Jan 11, 2011 | Keurig B60 Coffee Maker
My Keurig b30 doesn't brew and squirts hot water instead
heatman101
Nov 15, 2010 | Keurig B30 Mini Coffee Maker
How do you turn on a Keurig to get a cup of coffee - I hit the button and it says green and ready but nothing is coming out - I put the cup's worth of water in the side container - what do I do to get it...
I know on mine I have to open and close the chamber where I put my coffee. It then blinks ready and I press the size cup I want to brew. Hope this helps! :) And sometimes if there isn't enough water in the reservoir it won't brew so try and putting more than just a cup's worth of water in it :)
Sep 12, 2009 | Keurig B50 Coffee Maker
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
88 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
