My lg1832cw washing machine sounds like it has a dry bearing how do i remove the back to get at it. The motor is already off
  • radnel Apr 03, 2011
    if there is no cost to the service manual that would be good. (radnel@netago.ca) . Otherwise it soun
    ds like I may need a new washer. thanks
  • radnel Apr 04, 2011
    Hello, I just downloaded the manual. Thank you for sending it to me.
  • Washing Mach... Master
  • 2,605 Answers
Welcome to FixYa.
You can't really, unfortunately It is the bearing behind the basket (spin basket) and it is a non-serviceable part outside of replacing the complete outer tub assembly as shown here...
i.e.
As you can see the bearing is pressed into the outer tub. Once you get it appart you'll need to inspect the spider gear of the inner basket as well and if it is worn and scored (likely will be if the bearing is toast) i.e.
I can guide you step by step on "how to" both access this and repair it, but I think you'd be better served if I send you a complete service manual for your washer, it's up to you...whatever you think will best serve you.
You will need to provide an email address I can attach the "pdf" service manual to if you decide you indeed want it. I'll watch for your post and we can go from there.
Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Apr 03, 2011
  • 1 more comment
  • Mark MacDonald
    Mark MacDonald Apr 03, 2011
    Hello Radnel,
    There is no additional cost for me to provide you with the service manual.
    The only cost is what you pay here at FixYa for a solution to your inquiry. You accept the solution and I get paid, it's that simple.
    You can wait to accept my solution until you receive the email that I will send off as soon as I post this reply.
    As for replacing the washer, that's a judgment call. I'd ask myself
    1 ) WHAT DID YOU PAY FOR IT ?
    2 )HOW LONG AGO/ITS AGE ?
    3)WHAT IS THE CONDITION OF THE UNIT OVERALL ?
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 04, 2011
    Hello again,
    Just a follow up to confirm you got my email with manual attachment. Please let me know.
    Thank you.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Thank you for replying and you're welcome. Let me know what you decide or if I can assist you any further.
    Regards,
    Macmarkus :)
THERE'S A FUNNY NOISE COMING FROM THE BACK AND LOCATED AT THE DRUM NEAR TO WHAT SEEMS TO BE A GENERATOR (BY THE MAGNETS AND COILS INSIDE). KIND OF PLANE TURBINE SOUND. NEED TO KNOW HOW TO BRAKE IT APPART...
Your problem is a bearing of inner tub may also need spider assembly caused by overloading using non HE detergent 0r to much soap if noise gets worst it will take out seal and will start leaking thru-back side under stater motor that you call generator
Remove stater drum by holding inner drum and taking rear nut of stater drum after removing drum UN plug wire connections remove 4 bolts holding coil . then remove front of washer remove all counter waits remove all bolts from outer tub remove shocks remove springs and drain and vent hoses pull out the whole basket from unit pull tub in half remove inner tube Pop out both bearings back and front replace with new bearing and seal reverse back together same way you take apart may take 2 people heavy stuff
Oct 25, 2013 | LG WD-15517RD Front Loading Steam...
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
My dryer makes a squeaky sound during adrying
the front guides around the drum or the bearing at the back may be failing partially or bearings in the motor may have started to noise,there is also the chance that the belt idle pulleys have started to wear,more than lightly it is the belt idle pulleys that have dried up or the bushings have started to wear
Jun 30, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Spin cycles are becoming lowder and lowder
Tub back bearing or motor bearing worn.
the tub back seal has probably leaked and dried out the bearing
Mar 17, 2010 | LG WM-1832C Front Load Washer
When washer goes into spin cycle it sounds like a grinding noise that is very laud like a dry bearing very laud
This sounds like it's your clutch that is worn out and rubbing metal to metal. It has pads similar to a centrifugal clutch in small motors like chain saws etc. Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Mar 14, 2010 | Maytag Washing Machines
Have a admiral washing machine sounds like something is grinding inside while washing and spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 08, 2009 | Admiral AW22 Top Load Washer
Spins only with manually start /spin sounds like jet engine
Throw this machine out; it is a piece of junk. Transmission shaft is probably scored up so new bearings will do you no good. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Atlantis MAV9501E Top Load Washer
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Noisy
This will be either the motor bearings or the main drum bearing.
To find out, you need to take the back off, remove the belt, and spin the drum and motor by hand, and see which one squeeks.
My bet is the drum bearing. Good if it is as it's cheaper than a motor.
Look online for replacement parts HERE
You need to check if it is the right part for your machine, and may be cheaper elswhere.
It is a job for a competent DIY'er or technician. If you are unsure, employ the services of a domestic repair technician.
Thank you for using Fixya!
Jul 04, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
