Question about Car Audio & Video
How do I install the video brake bypass - Car Audio & Video
  • 10,319 Answers
Although driving while watching a movie is dangeous and idiotic. This How to is primarly for the passengers in the car. This How to will explain how to Bypass the Emergency Brake screen for a in dash DVD player.
Difficulty: Moderate Instructions things you'll need:
  • 12 volt or above momentary push button/switch
  • Wire Cutter (Diagonal Pliers)
  • Elecrical Tape (Black Tape)
    • 1 1st you will need to purchase a 12 volt or above Momentary Push Button/(Toggle)switch (about $5 Radio Shack)
    • 2 2nd Using the Diagonal Pliers adjust the length of the Radio's Emergency Brake Wire to your desire. Make sure you have enough wire so you can mount it where you can easily access it like beneath your steering wheel/ on the Dash Board.
    • 3 3rd Connect one end to the emergency brake wire from the radio and then connect the other wire from the switch to a ground to your car. You can use the same ground connection that you used for the radio and it will be fine. Make sure you wrap up the wires using the Electrical Tape to prevent shorts.
    • 4 4th (Using Button Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just press the button (4x Times)for one second and release it. On The fourth time the screen takes about 6 second to display the video.
    • 5 5th (Using Toggle Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just flip the swtich on and off (4x Times). On The fourth time the screen takes about 6 second to display the video.
    • 6 Now your Passengers can enjoy the ride & Movie!!
Posted on Apr 03, 2011
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
How do i bypass the parking brake switch in order for my video to play
I think the wire that should go to your hand brake is green, all you need to do to bypass this is hook it to an earth.
May 06, 2009 | Clarion MAX385VD Car DVD Player
Bypass emergency brake switch on 92 Legend w/Kenwood DNX7100
ground the green emergency brake wire just hook it into the radio ground and that will fix it
Nov 29, 2008 | Kenwood DNX7100 Car Video Player
Brake Bypass Code
I just spliced the brake wire into my cigarette lighter positive wire to provide the voltage necessary to bypass the parking brake requirement for video. Worked like a charm. It takes almost no voltage to bypass it. Even just licking your fingers and holding the bare wire allows video to show.
Sep 28, 2008 | Kenwood KVT-512 Car DVD Player
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
Mar 03, 2008 | Power Acoustik PTID-4005 Car Video Player
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Bypass
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
