I am trying to adjust the brightness on my monitor. I click the button but nothing happens.
  • Computers & ... Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Posted on Apr 03, 2011
How to view
Connect the power and data cables securely to the back of the monitor and the computer. Try plugging the computer and or monitor into another outlet to be sure there is no problem with the outlet. Go to the Control Panel and click on "System and Security" and then click on "Power Options. Click on "Change Plan Settings" and adjust the brightness of your screen. Push the button or buttons on the bottom front of the monitor to access the monitor controls. Scroll through the menus and look for a brightness control or contrast setting. Use the button or buttons on your monitor to adjust the brightness. Hope this helps
Jan 14, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
Brightness!
mcdevito75 here, You can try this, 1 of the buttons should say AUTO presss this button and the monitor will automatically adjust, and Or press the MENU button and see if there"s a brightness feature, I believe there is, you can use the little arrows on your monitor within the MENU options. First try the AUTO.
Jul 04, 2010 | KDS Radius RAD-7c 17" Flat Panel LCD...
How to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Jan 29, 2010 | NEC MultiSync FE700 17" CRT Monitor
My screen is too bright and hurts my eyes. How do I dim it a little?
he on the monitor you can find small buttons ,, you can just go select menu button from there select brightness section,, all this appear on display screen,, once click on button.. where u can adjust
Oct 05, 2009 | Acer V193w LCD Monitor
Im a graphic designer and my hp1502 screen is just to bright making me get all my colours wrong ,ive tried adjusting the controls but to nothing works ,is there something in circuit i can adjust to get my...
The best way is through the buttons in front pannel. It will bring an OSD (On screen Display). Adjust the brightness and contrast from there. ( But I guess you have tried it allready )
Then the other solution which i uses to brighten my display is Power Strip.
You can also lessen the brightness/sharpness/contrast.
Chech this link to read about it and a free trial download . Click here.
If helpful, kindly Rate.
Jul 18, 2009 | HP L1702 17" LCD Monitor
Dell moniter, brightness adjustment keeps coming on
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
Jun 06, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Acer Aspire 5630 screen brightness adjustment...
How do I adjust my brightness or contrast on my laptop? See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
