Question about Kitchen Ranges
Need a replacement for model rs670pxk-2 All the new ones seem to be different sizes how do we find a new one without having to cut out more s[ace
    New Friend:
Hi there, I am looking for the same thing. Did you happen to find a replacement? If so, do you mind sharing the model? Thank you!
Posted on Aug 07, 2016
I have an Oster prima latte machine and need a new rubber seel for under my coffee cup holder does anyone know where I can get one
take your seal to a hardware store i always go to ace hardware they have assortments so you only have to buy one instead of a bag of different sizes witch may not have your size.note:these are o rings.
Feb 08, 2015 | Oster Coffee Makers & Espresso Machines
What is the A-coil that is compatible with furnace model KG7SC072D24B?
Looking at the model # it appears that you may have a 2 ton unit. Evaporator coils come in different sizes -
You should be able to get the correct size by providing the A/C repair company with the name of the manufacturer and the Model Number.
Generic coils, should you need one because yours is no longer being manufactured, do come in all different sizes.
I don't know if you want to replace the evaporator coil or have a service company do it. But if you do there are some things you need to know.
If the unit is an older unit the evaporator coil along with the box it sets in needs to be replaced because the drain pan is probably rusted out.
Additionally the box the new coil sits in is is going to be different in size then the original.
So a transition will need to be made from the furnace to the new A-coil box.
So with all that being said - if you have a credible A/C company replacing the coil you won't have any problems with them finding a replacement coil. They are in the business of doing this type of work and come across this situation all the time.
Oct 06, 2014 | Heating & Cooling
I have a 96 Sebring convertible with a bad 2.5 in it problem is I can only seem to find the coupe engine without having to buy new I guess my question is would it work in my car or is it a major difference
well if you plan on swapping the engine with a bigger engine then your going to need a different transmission/trans axle depending if its RWD or FWD also your going to need motor mounts in different places, depending on the size of your radiator you will need to replace it, your best bet on saving money is to go to a junk yard or pick n pull and get one of those, there is a lot of things to do when swapping out an engine for a bigger size one, knowing Chrysler there alot of things, electronically as well
Jun 01, 2013 | Cars & Trucks
Cracked Screen
don't buy the Ace 2 GT-8160 glass , I tried one from ebay, (from cui1873 )took over a month delivery and is not even similar. different size glass, connection is on the other side, will not work. looking for correct glass also
Feb 01, 2013 | Cell Phones
If my Badger 5, 5/8hp disposal is leaking and needs to be replaced, do I need to replace it with the same exact model of can I replace it with a Badger 5 1/2hp disposal without having to replace the...
Generally speaking, a household disposal is a household disposal. The Badger is, IIRC, the same as the Kenmore, and several other brands. No, you won't have to change pipes. The pipes are the same. The only difference will be the power requirements.
Jul 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Please help me as I purchased a Rubbermaid Home & Office Cart model 4401 and need to know which are the correct caster wheels for it.Is it the 5 in. 2 rigid and the 2 swivel with the 4 holes or is it...
I see the description says, "500-lb. capacity model has ... 5in dia. casters for extra stability. .... Four nonmarking casters two swivel."
As to screw size, I can't estimate without seeing it, so I would suggest going to a place that sells it.
But you could also ask Rubbermaid:
"For replacement parts, please contact Rubbermaid Consumer Service by calling 1-888-895-2110 Monday through Friday, 8:30 am to 5:00 pm ET or by email using our contact form."
http://www.rubbermaid.com/supportCenter/Pages/ReplacementParts.aspx
Mar 12, 2011 | Garden
InSinkErator Badger 5, 1/2 HP Garbage Disposal: i need to extend the drain hose on new beko was ma...
Just upsize the hose to the next larger size and then back down to hook it on again....
This will allow you to extend it without getting in trouble...
heatman101
May 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Changin chain on 2002 honda shadow ace
Unless you are changing sprocket sizes you can not shorten the chain because removing even one link would not allow the ends to connect. Are you adjusting the chain as needed? Why do you want to shorten it?
Even if the factory chain has no master link (some are continuous these days) you can still grind off two pins carefully and push out a link to remove the chain, or simply cut it. That is what you must do when replacing the chain.
Apr 05, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Chain Size
Go to a web site like bikebandit.com and pick the make year and model of your bike to see the part diagrams. Find the drive chain page and it will usually tell the size of the chain.
Jan 14, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
A/c belt replacement
It should go right on without any hassle. Double check your belt. Buy another one at a different place, you can always return one of them. It sounds like the wrong size.
Aug 08, 2008 | 1991 Toyota Pickup
Kitchen Ranges Logo
136 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
