Question about Philips GC 2522 Iron
I need to descale my iron and don't have any instruction manual.
  • Philips Master
  • 43,501 Answers
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Posted on Apr 03, 2011
How does the descaler unit open on model 18465
The user manual is here with detailed instructions
http://uk.russellhobbs.com/pdf/18465_steam_generator.pdf
Changing the descale cartridge sounds like a right pain though. Good luck!
Aug 03, 2014 | Irons
How do I descale iron - Lost instruction Manual.
Put in the tank 50% water + 50% winegar
Put the temperature knob to max and let the steam flow out into a drain.
Repeat until necessary. This will eliminate escale. There are commercial products also but expensive ones
Apr 18, 2011 | Tefal Irons
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Aug 26, 2010 | Irons
No instructions with my ireon how do I descale my
Here is the link:
https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
May 06, 2010 | Bosch Irons
I need descaling instructions for Tefal Ultraglide easycord55...Mislaid instruction booklet....Thank you
thank you solved de scale instructions for Tefal Ultraglide easycord 55, found manual on net....
Jan 09, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Simac Steam Generator descaled incorrectly.
I don't think you can recover the iron. You could try to return the item !!!! but I don;t think that you will have much luck because of the incorrect descaling
Sep 15, 2009 | Irons
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
HOW DO I DESCALE A STEAM GENERATOR IRON
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Dec 19, 2008 | Maytag MLI7500A Iron
Philips GC 2522 Iron Logo
494 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
