Every time I put my camera's SD card into my HP Printer C3150, a red exclamation mark light blinks on and off, and the SD card does not appear on "My Computer," so I can't access my pictures. What should I do? My SD card's brand is PNY Optima SD 4 HC 60 mn HD 4GB, and it fits into the SD/MMC/MS/XD Slot in my HP Printer just fine, so I don't know whats wrong. Thank you for your time.
  • Office Equip... Master
  • 4,166 Answers
I am not an expert on such matters. It is possible the printer won't read the SD card because it wasn't formatted before use or was formatted by a computer using 64 bit software instead of 32 bit.
You could try using a card reader and downloading the images to your computer and printing from there.
Posted on Aug 11, 2017
  • 4090 Answers
SOURCE: My Kodak SD HC memory card won't work in my HP
HC stands for High capacity What is this cards size The printer may see it as bigger than the capacity it waqs designed to deal with
Posted on Jul 29, 2009
  • 161 Answers
SOURCE: memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Posted on Sep 10, 2009
  • 73 Answers
SOURCE: Hello, I have a HP Photosmart R742 7mm digital
Its look like you card reader doesnt support 4 GB memory card. You would need to try it on other memory card reader
Posted on Sep 23, 2009
SOURCE: PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Posted on Jan 07, 2010
SOURCE: i'm useing the pny optima sd/hc 60 hd 4gb scan
I had same problem. Neither computer nor printer would recognize the SDcard. I took the card to Walgreen's and the card was read just fine. I suspect that we are running XP and do not have the right driver; but I can't seem to find the right driver. Morgen
Posted on Jan 30, 2010
Hp photosmart c3150 keeps color light and check cartridge light keeps bliking after replacing with a new one.
It sounds like you ink cartridge is electrically bad; you can run the diagnostic 'tap 41' test to confirm. The HP 31xx printer 'access procedure' will be very similar to this HP Fxxx series access procedure:
http://www.youtube.com/watch?v=m-OM09NvNqg
Good luck:
inkjet411.com
Feb 19, 2013 | HP Photosmart C3150 Printer
Photosmart C3150 Printer: my hp photosmart C3150 all in one printer will not...
Check on a different wall outlet.
u could also take it to the store and ask them to check with a different power cable .. this will help us isolate the issue
May 18, 2010 | HP Photosmart C3150 Printer
SD card slot access Win7 Networked printer
INSTALL THE COMPLETE APPLICATON SOFTWARE OF C3100. YOU WILL GET THE OPTION THERE
Sep 12, 2009 | HP Photosmart C3150 Printer
Error: 0x88076c8e
hi CMlerma,
any time you see a "0x..." message, its referring to memory problems and there are many, many reasons this may appear. here are a couple support links from HP's site that might be helpful.
this one is specific to memory errors:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00489814&dlc=en&lc=en&jumpid=reg_R1002_USEN
this one is a link to general support/info help pages for your model:
http://h10025.www1.hp.com/ewfrf/wc/product?product=422000&lc=en&cc=us&dlc=en&lang=en&cc=us
hope this helps! - JW50
Oct 13, 2008 | HP PSC 2355 All-In-One InkJet Printer
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
jasbo
jasbo
