A load of wash got "stuck" at 22 minutes left on the wash cycle. I turned off the machine. I turned it back on. Now the door is locked. How can I unlock the door and restart the machine?
    Problem Solver:
  • 9 Answers
Try starting a cycle and then cancelling it. Could also be problem draining. Check pump filter. I have had this twice on my indesit washing machine. You have to take the front cover off the bottom and then unscrew the filter to check it. Be careful as it will gush with water if the drum isn't drained.
Check the drain pipe for blockage by disconnecting far end of it and lowering to floor level (in a bowl). If no blockage then water should drain out of the drum by gravity.
Posted on Apr 03, 2011
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
    http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
    May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
    Washing machine has 1 minute left on cycle stuck door wont open programme not finished
    Try the following, may work:
    Press the Start/Cancel button together until all the console Led's illuminate
    1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
    2. Default screen should return. Switch off.
    3. Wait for 2 minutes to try the door. If helped click.
    Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
    Lg front wont finish wash resets to spin cycle
    Sounds like the programme software control logic circuits are playing up. This is a job for a qualified Technician only. The control board may need replacing.
    Pay for a service call and just get a quote to fix it.
    If it's within your budget, fix it oherwise replace with another machine of your choice of brand and features.
    Poppa
    http://www.cdbaby.com/cd/poppamadison
    Apr 06, 2013 | LG WM2277H Front Load Washer
    The machine will "hang" with
    Check the pump sump cleaner. Under the front panel at the bottom. DC means the door is still sensed as open . If it occurs more often may need new door lock switch
    Oct 29, 2010 | Maytag MAH8700A Front Load Washer
    Can't interrupt the washing cycle on coin operated Mah21pddww
    Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
    Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Bosch classixx 1200 washing machine stalling mid-cycle
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
    Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
    Pl rate me 'very helpful' for the free help, thanks!
    Jun 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
    Door locked, start pause light flashing
    I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
    Jun 11, 2008 | GE WSXH208A Front Load Washer
    Washing Machines Logo
    136 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
