Question about Sony STR-D865
Cant get it out of protect mode i ve dissconnected everything. tried holding power button in . with no luck any suggestions? jeffree3@hotmail.com
    Brigadier General:
  • 8,546 Answers
Maybe if you resolve the reason it's self-protecting...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 03, 2011
My Kenwood KDC-MP142 in protect mode. is there a reset button??
My kenwood is stuck completely in protect mode. I ve everything listed and it wont come out of it. So should i assume the unit has gone bad?
Oct 20, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Dell desktop is stuck in sleep mode. I press the power button and it just flashes amber. Tried pressing the power button for a second but it still doesn't come on. I've also tried taking the...
You seem familiar with these technical issues so I'll assume you have swapped keyboards, Can you actually access BIOS, check if everything is online, Reset the Bios settings to their default (There should be an F button at the bottom)and try and reboot and hopefully this will work, there is a chance your motherboard has an issue try finding out the manufacturer and see if they can provide any help.Best of Luck
Jun 07, 2011 | Computers & Internet
I have a punch p850.4 amp that goes into protect mode as soon as its powered up , have checked and double checked all connections to make sure its all hooked right . even downloaded the pdf for the amp .
I have exactly the same problem, try a different speaker wire from your sub terminal to your amp terminal, if no luck you may have a loose connection on the wires on your sub, due to vibrations etc they can sometimes come loose, but very rare. worth checking though. 1 loose connection can make the amp go into protection mode. If all of these are fine, start from the beginning, ( I have tried this and i think its my speaker wire shorted out) 1st dissconnect all wires from amp. Then connect ground first, then your live. then power up amp, it it works andd not in protect mode your earth and live are fine, then connect your remote, then test, then speaker wire , then test, that way you can rule out bad connections and find any fault.
Mar 03, 2011 | Rockford Fosgate Punch P850.4 Car Amp
Stuck in protection mode tried everything voltage good wires good ground good open/close button dosen,t help me at all love amp please help
everything you've tryed is useless(with respect) because amp has shorted output transistors one or more and amp is in protection mode to protect your amp from further damage.take it to repair shop or try to locate blown transistor yourself.good luck
Dec 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
HP a1050y no power I tried all suggestions posted, and everything
Try Unpluging the power supply and press and hold the power button for about ten secs - leave it off for about two min and plug it back in and turn the computer on.
see if that work,
Thanks
Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
Error message says printer error see
found this on another forum. I had the same problem and this worked for the problem posted:
Found this on techsupportforum.com and it worked for me. Good Luck!
Press and HOLD all following buttons: Power, Load/Eject (I don't have this button, so I skipped this), Stop, B&W, Color. Continue to hold the buttons until "Init Eeprom" appears on the printer screen. Press Color button to clear protection counter.
The panel then told me to press the power button, I did. When it came back up, everything was fine.
Dec 17, 2009 | Epson Stylus CX6400 All-In-One InkJet...
I can't seem to get out of protect mode. Any suggestions
Hi disconnect everything, inputs speakers and leave power. If still in protect mode then there is a circuit problem, will have to send it in.
Best of luck
Jul 15, 2009 | Visonik V2508 2-Channel Amplifier
Cant set fax mode.Printer will fax out but will not receive a fax
Unplug the Power Supply from the printer.......
Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button..........
Now the Printer will ask for the Date Time and Country Language.........
Set everything up......
Now try to Print
Good Luck............
Jan 31, 2009 | Lexmark X4270 All-In-One InkJet Printer
73 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
