Question about eMachines eME5272537 156Inch Laptop PC Notebook
My scroll line on my touchpad is not working - eMachines eME5272537 156Inch Laptop PC Notebook
  • 2,296 Answers
To fix your eMachines's touchpad, follow the information from this link.
Posted on Apr 09, 2011
Touchpad won't scroll
hi there.
this is all i could find.
Why my TouchPad is not working in laptop Acer? Enable/disable your touchpad - Many systems allow you to turn the touchpad On or Off by pressing the FN and F7 keys at the same time. ... Reinstall touchpad drivers - Missing or incorrect drivers may cause your touchpad to not work properly. Check in device manager to make sure your touchpad is reporting properly.27 Oct 2014
Touchpad troubleshooting - Acer Community - 307854
community.acer.com/t5/Knowledge-Base/Touchpad-troubleshooting/ta-p/307854 Search for: Why my TouchPad is not working in laptop Acer?
or go to this link and read up some more if you need to.
Acer Aspire Notebook PC Touchpad won scroll Google Search
Nov 27, 2017 | Acer Aspire E1-571-6492 15.6" Notebook PC...
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
My scrollbar will not work. I can use my touchpad just right and right click and left click, but I cannot scroll on a page I have to use my arrow keys, how do I fix this?
b>
Feb 03, 2013 | Acer Aspire 5750-6438 - 25519
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
I can't get my Acer 5534 touchpad to scroll up or down. I can move the arrow, but when I go to scroll up or down it wont move and I get a small dark circle under the arrow. It has done it before but...
go to control panel and open mouse option, from here selct the "touchpad" tab,now you should see a line that display the name of the your hardware ( the touchpad name) and below there is a button named "advance configuration" or simply "configuration" or "setting" ecc. Push it.
From the new windows you can control a very large number of options ,not only you can activate scroll in two direction ,but you can also decide the dimension of the touched area interested in the action.
Feb 05, 2011 | Acer Aspire 5315 Notebook
Toshiba Laptop Scroll problems
Scrolling is not obvious because there is no area actually marked on the touchpad that shows where it is. Also if you tap the area before doing it, it won't work. Even for me it is hit and miss, since I don't practice with it enough. You could adjust the area that it uses and make it bigger, but then that gets in the way of regular mouse usage.
I would suggest that you try it at a store, and have a sales person show you how to use it.
As for the curser jumping even with that checkmark, well it can. All that checkmark does is turn off the touchpad for a brief moment while oyu are typing. Pause for a second and the touchpad is active again, then slightly bump the touchpad and your mouse will jump. Prove this to yourself by turning off the touchpad entirely with Fn+F9.
In the touchpad settings you can adjust various things to suit you. For example increase the slider for the diable while typing chekmark oyu mentioned, decrease sensitivity, turn off tapping support, etc. Each have thier pros and cons, and that is why they are adjustable.
Also, since you repaired it, I assume they tested it to make sure it was working. And if the touchpad is working, then the jumping adn the scrolling have nothing to do with a hardware problem, it is all software. You can replace hardware till the cows come home and it won't change things. So look at the software settings for scrolling and for "jumping".
This signature left intentionally blank.
Please let me know if you have any further questions or concerns.
Thanks.
May 07, 2010 | Toshiba Satellite A3 A355D-S6922 Notebook
Touchpad scrolling not working
there can be two problems
1. something wrong with ur HW, which is quite negligible, as there is very less possiilty of that.
2. most possibly you dont have installed the drivers for ur touchpad. pls install that and the problem will be resolved
Jun 15, 2009 | Computers & Internet
The scroll function doesn't work
Download the latest driver for the synaptics touchpad for your laptop from support.dell.com. Most likely the driver for your touchpad was not fully installed or may have been damaged. Install that and you could get the scroll on your touchpad back.
May 09, 2009 | Dell Inspiron E1505 Notebook
eMachines eME5272537 156Inch Laptop PC Notebook Logo
421 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
