Question about RCA Audio Players & Recorders
My rca lyra 1028 is only reading 18 songs and does not read my memory card. How do i format my player?
This player only supports cards that are no larger than 256 MB. If your card is larger than this, the player will not read it.
Posted on Oct 03, 2008
The RCA Lyra 1090a says bad or missing lyrasys
What i do is i never put songs in my internal memory...this way you never have to worry about formating the internal memory....so i have several exteral card i use say one for country or rock and its so easy to format a exteral card just place it in ur card reader if ur using a laptop them go to my computer right click on ur card that youll find then youll notice on the list theres format so its so easy...im sure its asking you to format ur drive because you must have a few corrupted files....best of all when adding music just pull ur external card out place it in a reader fill ur card with music then insert it back in ur device...this way ur getting away with using any firmware....by the way take any disc that came with ur Lyra and chuck it in the garbage that 90 percent of all ur problems
Nov 25, 2009 | RCA Lyra RD1090 MP3 Player
I NEED TO FIX THIS
First off, let's talk about the bad news: there are a lot of people who complain about just how picky the Lyra is about which SD cards it can work with. Indeed, the later model Lyra devices on the RCA site itself say "now supports more SD cards" as a feature. Ouch.
Go to a popular memory card vendor like 4AllMemory and you'll find that a search for Lyra-compatible SD cards shows barely a half-dozen matches Lyra-compatible SD Cards
Another issue: Firmware Update 615 you might need to update your firmware to gain better compatibility with various SD cards:targets this specific problem.
While we're listing all the potential problems, it's also worth reporting that there are some reports of Lexar memory cards that require a higher voltage than regular SD cards, meaning that the Lyra either wont start at all, or its battery drains faster than usual.
Comment from the web on this: "Some Lexar memory cards require at least 2.7v to operate. Some Lyra models only use a single AA battery (1.5v). This MAY mean the mp3 player doesn't have enough power to run the card (depends on if RCA used the right parts to temporarily boost the internal voltage to 3v through a booster circuit or capacitors). This may vary between models and even between different releases of the same model. This also may explain why you can hook the device up via usband send/receive files to the card fine but then have problems after you disconnect (a USB wire can provide some amount of power. My previous nexxtech player would actually turn on without a battery when I plugged the usb wire in). "
Generally, you should be hooking your Lyra up to your PC, then running the standard PC disk formatting utility. But even then, here's what RCA warns:
"We have recently discovered an incompatibility with the RD1080/RD1090, windows XP(Service Pack One) and some newer SD cards. We are presently working with microsoftto identify the best approach to correct the issue. Until a solution is implemented, we suggest that you use MMC cards instead of SD. "
To format an external device in Windows XP, just find the device in your "My Computer" window, then right-click on it and choose Format.... You'll see something like this:
windows-format-disk-options.png (since I don't have a Lyra, this shows the default for my second hard drive. Your settings would be similar, but probably a bit smaller!)
RCA offers zero assistance on the best way to format an SD Card for use with the Lyra, as far as I can tell, so I'll say that my expectation is that NTFS will work, you should use a short, letters-only volume label, and you should not choose either "Quick Format" or to "Enable Compression".
When you're ready, click on Start and it should only take a few seconds for the SD card to be ready to roll with your Lyra.
If it works.
please rank if this helps
May 24, 2009 | RCA H100 MP3 Player
My RCA lyra RD1076C wont play songs from the memory card
FAT32 is not compatible with the Lyra, you must use FAT not FAT32
Nov 07, 2008 | Audio Players & Recorders
Rca lyra won't read memory card
WMA files come in two formats DRM & non-DRM. Change your setting in Windows media player (Options - Copy Music) and re-rip the music CD. You can copy both versions but one will play but not the other.
Jan 11, 2008 | RCA Lyra RD1072 MP3 Player
512 MB SD CARD
Once you insert the memory card I believe it mixes the songs on the player's internal memory with the memory card's songs.
Jan 04, 2008 | RCA Lyra RD1072 MP3 Player
Will not read the sandisk card
When RCA first came out with the Lyra series the only way to get music1.gif onto the device was by using musicmatch jukebox that would convert your mp31.gif file to mpy before downloading it to the device. But now RCA has come out with a new firm ware update for these mp3 players that improved the players playback quality plus enabled it to use .WMA files. so first go to RCA support http://support.rcaaudiovideo.com/select.aspx?u=downloads and find your player and download the firmware and drivers (if needed) upgrade and install to your player its very easy and instructions are at the same site. You can now convert your music to .wma or use the free Real player that will convert mp3 to wma1.gif at the kbps that you request before loading it on. If your music is all ready in wma format you can use windows media player to send the files to your player. One last thing the .wma files that you put on your Lyra player need to be at least 128kbps or higher enhanced playback quality of wma files (160 kbps to 256 kbps).
Oct 25, 2007 | RCA Lyra RD1080 MP3 Player
RCA Lyra RD2317
Remember when you format memory like a hard drive you erase everything. Move music to your internal mp3 memory and do a profile - folders should appear. If you have flashed your player with the firmware update you can get 520 songs on the player for both internal and external combined but be warned that if you exceed this count your player will start to forget the earlier loaded songs - listed but not addressable (playable). The same is for the folder count eg. add album = artist + ablum title (min 2 folders). Plus always profile your songs after loading new music or deleting as this is an index build process to play song 152 = title x. This includes accidental radio recordings to MP3s. RD2312 , RD2315, RD2317 Lyra™ mp3 flash player Firmware/Application Upgrade Version 3.11 fixes:
  • Supports a total of 520 songs, in up to 50 folders, with up to 8 levels of subfolders.
Aug 06, 2007 | RCA Lyra RD2317 (1 GB) MP3 Player
Memory card question
It should read the songs automatically. Once you have inserted the card with MP3 Format or WMA formatted songs it should read it.
Apr 17, 2007 | RCA Lyra RD1072 MP3 Player
Unable to download songs onto SD card
umm i just want to learn how to put stuff onto my sd then on my wii
Aug 01, 2006 | RCA Lyra RD1071 MP3 Player
Problem using Scan Disk memory card
I had the same problem, and that is what RCA answer me: "... Due to a unique FAT12/16 cluster size requirement, the supplied format utility that comes with the RD1021/RD1071/RD1075 MUST BE used on all SD/MMC cards before they will work in the RD1021/RD1071/RD1075. Once formatted, these cards will still be FAT compatible and should still work with other devices, i.e. RD1080. The format utility can be found under "Programs", "Lyra Personal Audio Player", "RD1021,RD1071,RD1075", "Format Media" once your software has been correctly installed from the included RCA CD-ROM. ..."
Jan 15, 2006 | RCA Lyra RD1072 MP3 Player
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
