Question about Jet 707200 10Inch Band Saw
I have a new JET JWBS-10OS. I bought it rather than a scroll saw because it is more versatile, but I do need it for scroll work. I purchased a 1/8 inch blade and had trouble with the installation. The JET tech. I talked to said the problem was inferior tires. After several weeks delay I received two new tires and installed them. I still cannot get the 1/8 inch blade to track. After much time centering it on the new tires, and carefull adjusting the tracking knob, it continues to wander back and forth across the tire and ultimately comes off. Also, the bearing guides do not have sufficient adjustment to accomodate the 1/8 inch blade. Is this saw really designed and built to work with a 1/8 inch blade?
  • 710 Answers
I'm not a Jet tech, just a bandsaw owner.
First, when you are adjusting the tracking knob, are you turning the wheel by hand for several revolutions to be sure which way it is running before making another adjustment? After tweaking it, you should turn it a bit to let it settle in. Also, be sure to tighten the adjustment knob down before turning it on.
The bearing guides have more adjustment places than just the finger adjusters. On mine, a Steel City, I can move the entire guide holders back and forth, and can also move the entire guide set up back and forth. The guides are there to keep your blade from having too much movement while cutting. They are not supposed to actually touch the blade though. I adjust mine with a dollar bill between the guide and blade. If you have one guide that isn't exactly perfect, don't worry about it. The blade guard will also keep the blade from wandering.
I've never used my bandsaw for scrolling work, so am not familiar with the 1/8 inch blade. Should work if you can get your tire adjusted correctly.
Good luck.
I hope this helps. If it does, I'd appreciate a vote or comment. Thanks,
Handie Andie
Posted on Apr 03, 2011
  • firesafe1 Apr 03, 2011
    Andie,
    Thanks for getting back to me. After centering the blade I added enough tension to clear the blade and let it run free. I have turned the wheel by hand so many times I have a blister. After several rotations to determine the direction of the correction needed I tweeked the tracking knob until the blade appeared to run true in the middle. Then I locked down the tracking knob, applied a little more tension and increased the speed of the rotation, still by hand. The blade would not track in the middle but wandered from front to back until it either came off the wheel or I stopped the rotation. As for the guide bearings, the only adjustments are front to back, and a little side to side. The side to side adjustment utilizes an off center bearing shaft that can be turned moving the bearing closer or futher away from the blade.. While there is plenty of adjustment front to back by sliding the bearing shaft in and out, the adjustment side to side is inadequate to accomodate the blade. I can force the blade between the guide bearings and it will continue to ride on one of them or it comes into contact with the face of the bearing. Either way this is a NO-NO and it appears to me that the guide bearing set up is a design or manufacturing flaw.
    Again thanks for yor input and effort to help!
  • Handie Andie
    Handie Andie Apr 04, 2011
    Thanks for writing back.
    It sounds like one of the wheels is either not on securely or is out of balance. This would have to replaced. Could also be the shaft that the wheels are on is bent slightly.
    It sounds like you got a defective product from my view. I'd contact the people you bought it from and speak to them.
    I'm sorry I couldn't have been of more help to you.
    Good luck,
    Handie Andie
Need instruction manual, where can I get it?
An instruction manual for what?
Try looking the manufacturer up online & search their literature available.
Mar 05, 2015 | Jet Deluxe Pro Band Saw 14in., Model...
Replace guide bearings on jwbs-18 saw
" That one will be a press fit onto that eccentric shaft. Small bearings like that are easy to drive off with a suitable punch or mandrel. Simply stand it up in the jaws of a vise so the jaw edges contact the outer rim of the bearing and use a hammer to drive it out. Put a washer or similar bit of metal between the shaft end and the punch to protect the face."
Make sure before you put the new bearing on that the shaft is clean and smooth.
Nov 07, 2013 | Jet Machinery Jet Equipment 708750B...
Tire comes off wheel
Are you using new tires? Urethane or rubber? Make sure the adjustment are correct or probably you need to replace the
tires. I am using ulta blue urethane tires because it lasts longer and it doesn't need gluing. Urethanes are more durable
than rubber. I got mine on http://bandsawparts.com/ultra_blue_urethane_tires.cfm .
Jan 31, 2013 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
I am looking for a Jet 1$" manual. Model
Hi Dean,
The manual is available here:
http://www.retrevo.com/support/Jet-JWBS-14CS-manual/id/23013ci556/t/2/
Click on the red download button.
You just need to enter an e-mail address on the download page for them to send you junk mail !
Hope this helps !
May 07, 2011 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
What is the band saw blade length for a JWBS-20-1 Jet Band saw.
The 20 inch band saw uses a 150 inch blade and I'm envious. The 20 inches refers to the wheel diameter
For more information:
http://www.redmond-machinery.com/Jet%20JWBS-20.htm
I'd gladly trade.
Feb 20, 2011 | Garden
My 16 inch Band saw briefly bogged on a log resaw project. I think it may have tripped the fuse. What is the recommended fix for the fuse or switch?
No fuse for the motor has an overload protected circuit and resets itself usually within minutes. Your home circuit breaker or fuse in the electrical box needs to be checked.
Apr 06, 2010 | Jet JWBS-16B 708749B 16-inch Bandsaw
Top wheel part broke off
I suspect the part you need is 150086 "Upper Wheel Shaft". You can confirm this by checking the exploded diagram for your bandsaw which can be downloaded at http://content.wmhtoolgroup.com/manuals/708115K_man.pdf.
See page 25 for exploded diagram showing wheel shafts, bearings, etc..
It might be worth checking with JET about warranty since I believe that band saw has a 5 year warranty. You can check here for a service center near you.
Jan 10, 2010 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Tire keeps rolling off
I'd say you have the wrong size tires, or at least defective or poor quality ones. They should be pretty tricky to get onto the wheels, requiring some leverage as you work them on, but they should be a very tight fit which will prevent them from moving. Sounds like the tires are too lose to me.
Feb 16, 2009 | Jet JWBS-16B 708749B 16-inch Bandsaw
Jet model jwbs-14cs bandsaw purchased used, need manual
http://www.cpojettools.com/products/708115k.html
Scroll down and click the "Manuals" tab. Your free PDF awaits...
Dec 28, 2008 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Jet 707200 10Inch Band Saw Logo
163 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
