Question about Technics SL-BD20D Turntable
I have a technics sl-bd20d and I have a constant hum from the left speaker when I turn on the phono. The right speaker works fine. I did ground the turntable to the receiver. What might be causing this?
    Brigadier General:
  • 8,546 Answers
Poor ground at the phono cartridge. Turn your receiver off and remove/reseat the cartridge and/or the tiny leads to it.
Posted on Apr 03, 2011
I recently purchased an onkyo tx-nr626 receiver with phono input. When connected I don't get full sound.
Different cartridges put out various levels based upon their technology - make sure you are using the proper input for their output. A line level input 1V P-P won't work on most phono cartridges and will require a preamp to boost it to the higher level.
Dec 23, 2013 | Technics SL-BD20D Turntable
Technics sl-BD20D turntable, attached pre amp but now have a loud hum, noticed there is a round jack with a pin in it next to the 2 outputs. Is this for grounding? Are there special cables that fit that...
Hi, Yes your turntable needs to be grounded to get rid of hum. Make sure that your turntable, preamp and amp are all powered from the same point. Most preamps do not have a grounding connection on them and when they do it is normally on the same side that the rcas from your turntable connect too. What is the make and model of your preamp. I will check it out. To earth to a preamp without a grounding connection do this. Take the grounding cable from your TT and slip it in the side of one of the 2 rca connections as you plug them in. That will ground your TT to the amp. If it doesn't then swap the ground lead to the other rca. Cheers John. Styluscity.com.
Oct 05, 2011 | Technics SL-1200MK2 Turntable
I dont have the orginal ground wire for my Technics SL-BD20D turntable someone told me i could use rca cables to ground it, i have a pre amp cause my main amp didnt have phono jacks on the back of it.
You don't need the original ground wire for Technics SL-BD20D turntable,
any plain cable can be used for this purpose...
you should connect turntable to your pre amp,should be a "phone" input at the back...
here are some suggestions for grounding....
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    Jun 22, 2011 | Technics SL-BD20D Turntable
    Turntable output level too low and plain compared to CD, etc.
    Get an external pre-amp. They range in price from 25-100 and more, depending on the capabilities. All over Ebay, and electronics sites. That will fix your problem. Hope this helps
    Jul 06, 2009 | Technics SL-BD20D Turntable
    Buzz coming from speakers on phono input
    is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
    Jun 21, 2009 | Technics SL-BD20D Turntable
    My stereo receive hums annoyingly when I use my record turntable.
    Just a suggestion, make sure the power outlet/s is grounded and that the polarity on both plugs are correct.
    Tan Orexic
    Mar 12, 2009 | Audio Players & Recorders
    Buzz....hum problem from turntable....
    Did you ground the turntable? Most of them have a ground wire located somewhere that connects to a screw on your electrical outlet. You could be getting hum from your pre-amp if it is a low quality one. Try unhooking the pre-amp, if that is the problem you won't hear the hum. If the turntable ground is the problem you won't hear music with no pre-amp but you will still hear the hum.
    Jan 11, 2009 | Technics SL-BD20D Turntable
    Problem
    Make sure your ground wire is connected. I know Serato does not work properly if your ground wire is connected.
    Also, make sure your running the connection from the Line Out of the Serato box into the LINE IN on your mixer. You can use the Phono Input also, but I generally tell people to use the line input to avoid any issues. Regardless of which input you use, make sure that your Serato software is either set to LINE or PHONO, otherwise it wont run properly.
    - DJPROLAB
    Feb 14, 2008 | Technics SL-1210 Turntable
    No Sound out of Left side
    is it possible to swap the left and right wires on the needle cartridge? does the sound change sides? if yes bad cartridge if you still only get sound from right side try changing around the rca phono plugs
    Jan 04, 2008 | Technics SL-BD22 Turntable
    Technics SL-BD20D Turntable Logo
    180 people viewed this question
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    T-Comtech Repairs
    T-Comtech Repairs
    Electro Med Services...
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
