Question about Rosco I-Cue Intelligent Mirror (Requires 24V DC Power Supply)
Hi there, the theatre I work at has 4 rosco i-cue mirrors, we've recently started having problems with 2 of them. after being on for a half-hour or more, the mirrors will suddenly begin to miss their mark consistently by about 5 feet (over a throw of 40) in the same direction. when the power supply is reset, and the mirrors re-initialize, their positions once again become correct until the problem occurs again. There is only 20' of cable between the PSU and the icues, and a return line has been applied to no effect. Is this behaviour something that can be expected when an i-cue reaches the age of 5 or 6 years? Any advice is welcomed, my theatre is planning on purchasing a new unit tomorrow morning to replace the first problematic one, but a second has started having trouble today. Thank you for your time, -Garrett G. Barker
  • Rosco Master
  • 15,645 Answers
I believe that because of the high heat that they are exposed to that there is a servo sensor array that is having issues and needs to be replaced. Rosco recommends contacting the supplier and having them sent in for service.
Posted on Apr 03, 2011
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
I have a 2000 gxl landcruiser 6 cyl which generally runs and starts well, but intermittently it will just wind over but won't kick. Wait about half an hour or so then it starts. What is the Problem?
Hi there, check that yr ballast resistor is working properly if it has one - other than that it could be the computer has a glitch or a sensor is loose or not connected properly!!!!Check the air filter isnt clogged 2!!! When did it start doing it - Has the car been recently through water or real dusty roads??? Good luck!!!!
Nov 23, 2013 | 2000 Toyota Land Cruiser
Sony Home Theatre System Turning Off
Appears that you have a bad cap in the power supply that is changing value as it heats up. Hard to find - only thing you can do is go to suspected units and replace them hoping that you got the bad one. Or just wait till it finally pops.
Apr 02, 2017 | Sony Home Theater: DAV-DZ870W ALL REGION...
My Hp 5610xi is printing very slowly
Hi Elijah,
Remove both the cartridges, Clean the contacts ( Electrical/golden contacts ) with Lint free cloth. If possible, use a Cue tip to clean the contacts inside the printer cartridge slot.
After you have done this, reinstall the cartridges and it goes thru Alignment process.
Hope this fixes the issue.
Regards,
Sean
Aug 10, 2012 | Office Equipment & Supplies
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Cdj-500ll cue button repair
the faulty button will not stop it from playing well... replacing them is not hard so long as you have some experience with a soldering iron.
Clean the laser lens with a cotton bud wet with windex... then use a dry one to be sure no residue is left. If it still mistracks... new optics required!. You willl need a pioneer service agent to do this for you. A little complex for the first timer :)
Jan 08, 2008 | Pioneer CDJ-500II CD Player
Rosco I-Cue Intelligent Mirror (Requires 24V DC Power Supply) Logo
47 people viewed this question
Top Rosco Home Security Experts
Lawrence Oravetz
Are you a Rosco Home Security Expert? Answer questions, earn points and help others
