Question about Maytag Dishwashers
Ok my dish washer is not cleaning my dishes my water temp is about 130 at the sink my water pressure is around 34 psi. i am on my own well and i have a fiter on it. the dishwasher is a year old any ideas
  • Maytag Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Apr 03, 2011
Will not clean dishes
Sometimes because of water pressure the inlet valve doesn't allow enough water into the machine to satisfy the float switch so you don't have enough water to completely clean the dishes.Manufacturers install whats called a flow washer to control the flow of water into the machine in case of too much water pressure. What you can do is remove the flow washer from the valve itself to allow enough water to enter the machine. The other problem could be that the water is not hot enough. Some water heaters are set to 120 deg. to save on utility bills. To clean effectively the dishwasher water temp needs to be at least 160 deg. which is the temp restaurants use to clean and sterilize their dishes. Check to see if your dishwasher has a water heat switch on the control panel that will increase the water temp to 160 deg. If not just turn up your water heater temp. To check water flow just open the door when it is finished with the first fill right before it starts washing and check to see if the float switch is satisfied. You can check it by just pushing down on it and listening for a click. Either one of these should solve your dirty dish problem. Good luck
Nov 08, 2012 | Whirlpool Dishwashers
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
OK, so if the dishes are not getting cleaned, particularly anything plastic, then what?
Is the water around 130 F, if so make sure you run the water at your sink till the line fills with hot water before starting the machine. Make sure your getting enough water and that the spray arms are turning and clean.
Nov 22, 2010 | LG LDF9810ST Built-in Dishwasher
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
I have grit on my dishes after the wash cycle completes, jet dry seems to be working? Dishwasher is draining.
use only cascade complete cleaner, clean unit remove basket motor cover chopper cover clean and vac out trash washer all screens increase water temp. to 130 degrees if no children in home if children in home not over 125 degrees temp. monthly run dishwasher cleaner product through waser cost around 10 $ at lowes
Feb 05, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Washer not cleaning grease off dishes
try this most common mistake made is not getting hot water to the washer on the first wash don't care what brand hot water cleans dishes 130-136 best but you have to bring the hot water to the washer before you start it some lines can run a half gallon to the sink before the hot gets there run the water at the faucet till its so hot you cant stand it then start the washer 0 ohms ok
Mar 11, 2009 | GE 24 in. GSD3220Z Built-in Dishwasher
DISHES COME OUT WITH DIRT ON THEM
Your incoming water temp should be about 140 degrees. If not boost your water heater temp.
Check the dishwasher drain line. It should be tied up under the bottom of the sink to prevent sink water from backing down the drain into the DW.
Feb 27, 2009 | LG Dishwashers
Dishwasher Soap scum left on dishes
the problem is hard water. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Nov 01, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Low water pressure
Is the hot water faucet under the sink open all the way?
Miss Midget
Nov 02, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
46 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
