Question about Philips Televison & Video
As soon as i plug in my 42' flat screen philips hd tv, it just starts making a clicking noise over and over!!!!!
    Scholar:
  • 67 Answers
It sounds like the relay on the power supply pcb. What make and model is it? You might want to check the power supply pcb capacitors to see if there are any that are puffed up. To do this you need to place the tv face down on a padded surface that will support the whole tv. This is to protect the panel from damage. Then remove all screws that are securing the back of the the tv. Remove the back and check the power supply pcb. This is the board with the power cord going to it. If they are puffed they need to be replaced with equal or slightly greated values. The values are mfd and voltage. You will need a soldering iron to remove and install the new caps. If caps look good, then check the voltage levels of the dc output (marked on board next to the connector) with a dc multimeter. If all the voltages are correct and constant, then your power supply is good. But, this does sound like a power supply issue
Posted on Apr 03, 2011
Tv will not turn on. Makes on going clicking sound only.
http://www.shopjimmy.com/philips-996500042146-power-supply-unit.htm That is the most likely cause of your problem.
Aug 25, 2015 | Philips 42PFL5332D 42 in. LCD Television
How do I fix a clicking Philips 42PF5321/10 Plasma TV?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 01, 2014 | Philips 42PF9966 42 in. HD-Ready Plasma...
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
The tv started to make clicking noises and now it wont turn on
The board where the a/c power cord plug into it,that the power supply board it dead.Take ur tv aparts replaced the power supply board,ur tv should have stable power again and work.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 23, 2010 | Philips 42PF9630A 42 in. Plasma Television
Screen goes black tv stays on. Turn off and on and TV's fine.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Mar 20, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Replacement fan for a Philips 44pl9523
Radio shack. check the voltage and make sure you get the right size for you tv.
Thanks
C Dill
Sep 10, 2008 | Televison & Video
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Televison & Video Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
