Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Compressor very warm and not working - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 03, 2011
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
May 01, 2013 | Refrigerators
Jenn Aire side by side, both sides warm, PTC replaced.
If you hear it trying to come on, (the lights may even dim more than normal) followed by a "tink" noise, it's the compressor.
Jan 11, 2008 | Refrigerators
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
My freezer is not working
Check compressor working. If not try with replacing relay. If compressor working, check warm in condenser coil by keeping your hand. If warm, check whistling sound in freezer. If no warm gas leak. If warm and no whistling sound in freezer, chocked system.
For gas leak find leak and arrest. Then vacuum and do gas charging.
For chock, release all gas, flush out system, replace filter drier, vacuum and do gas charging. Call professional repairman to do it. Thanks.
Jan 28, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Stopped cooling
1. Check power to relay. 2.Check compressor is working by holding amps meter in phase or neutral wire. 3. If compressor is not working, replace relay and check. If compressor working check gas in the system by holding your hand on condenser coil. It should be warm. If no warm, no gas. If warm and check for whistling sound in freezer. If no sound system chock. Call repairman to rectify.
4. Check defrost timer and thermostat or on. If it's not solved the problem, please write clearly type of problem you faced. Thanks.
Jan 23, 2011 | Viking Professional VCBB363SS Stainless...
Fridge is getting warm & making a funny sound could it be compressor?
It could be the compressor or the start relay. If you hear a click sound, then your relay is good and your compressor is shot. If you do not hear a clicking sound, then your compressor is good and your relay is shot. Also check to make sure that under operation even if the compressor does not work the fan should still be spinning, even if it is warm air. Please rate
Jun 04, 2010 | Kenmore 57029 Side by Side Refrigerator
Refer warming / no compressor / no fan
If the fan doesn't work , the compressor overheats and shut off by the overload protection.I would replace the fan which will cost no more than $30.
Sep 19, 2009 | Refrigerators
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Danby DDR586R dehumidifier shouts hot air, it was shooting cool air before, what can the problem be?
Here is Danby's official response to a similar question on their FAQ page for Dehumidifiers:
https://www.danby.com/faqs.php?cat=12
Q) When the dehumidifier is operating, is it normal for the expelled air to be quite warm? We find that the dehumidifier is warming up the room noticeably (a finished basement).
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
May 07, 2009 | Dehumidifiers
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
29 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
