Question about Weber Genesis Silver B Grill
There are three rows of flames on my grill. the middle one does not light.
  • 10,865 Answers
Hello bob...this problem is almost always due to rust, dirt, spider webs etc. in these components that said, remove all of the removable parts from within the grill and clean them up with a wire brush and a shop vac or use a compressor to blow the debris out of them then reassemble them and it should light. Joe
Posted on Apr 03, 2011
I have a brinkmann 3 burner grill, the middle burner flames, but the outside ones do not, i just bought it today. How do I light the outside burners?
I am not sure, but I think the Brinkman uses the ignitor to light one burner and the other burners light after the first one allowing the flame to "crossover".
Gary
Sep 18, 2011 | Brinkmann 810-8410-S Stainless Steel...
Model 463420608. 1 of 4 burners allows flames to come out the front of grill around knob. Any ideas?
gas leak loose control knob screws heed screwing in also check burner is not block causing light back
Aug 25, 2011 | Char-Broil CharBroil 4637318 Grill
I have a 3 burner CaptnCook gas grill. The middle burner has a single flame when I try to light but does not light the whole burner row, just right at the front only. The right and left will not light at...
The problem lies with the grill's regulator and how the gas tank valve was opened.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 23, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Weber grill one row of burner does not light
A clogged burner possible caused by an insect nest, or the pathway is disrupted for the pilot flame to travel to the next burner, or stopped up or face.
Apr 03, 2011 | Weber Genesis Silver A Grill
I am getting very low blue flames, when I light the back or middle burner the flames get smaller and sometimes go out. Grill not getting hot. Could this be the regulator??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 23, 2010 | Weber Genesis Silver B Grill
My grill will no longer lights all three rows. I
My Weber is almost as old as yours and I had a similar problem. I removed the grates and cleaned the inside and checked the holes along the sides of the burners. The burners tend to build up cooking residue along the edge a restrict the gas flow. Try an aggreesive cleaning of the interior.
Jun 11, 2010 | Weber Genesis Silver B Grill
Burners do not adjust and are on full blast and uneven.
The Controls, once they ware out they are not serviceable most of the time.
May 20, 2010 | Jenn-Air JLG7130A
As you light additional burners, flame dies down to almost nothing
did this problem just start? if so check your regulator or the main line for a crimp or obstruction.
May 16, 2009 | Grilling
Weber Genesis Silver B Grill Logo
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
