Question about Black & Decker Tools & Hardware - Others
How do I change the sandpaper on my Black and Decker Dual Action Sander 7420? Pictured on the far right. http://www.purplewaveauction.com/a/2009/20090423ervin/9462.JPG
bozcro
  • 867 Answers
SOURCE: sandpaper sliding off
there isnt enough tension on the belt, hence the side to side movement. keep tightening the spring until it stops
Posted on Jul 22, 2009
  • 73 Answers
SOURCE: sandpaper keeps come off
probably the typer disk you are using. cheep disks will not stay on long.
Posted on Oct 02, 2009
miket756
  • 2702 Answers
SOURCE: How do I change the sandpaper in my
there are many types of sizes for this sander check you have the right size first,,, after that check that the return springs in the belt tenshioner are poping out fully
Posted on Nov 15, 2009
  • 8 Answers
SOURCE: Black & Decker Cyclone won't power on
If the sander was on for a long period of time maybe 20 mins or so then the switch has probably stuck in the off position when you turned off. Try a new switch or test the old one. Try Solent Tools on 023 80578057 for spares or further advice.
Posted on Mar 11, 2010
puertobori
  • 7733 Answers
SOURCE: How do I secure a
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Posted on Nov 08, 2010
74-674 sandpaper black & decker sandpaper
Have you tried the hardware store where the sanders are sold?
Jan 01, 2016 | Sander Tools & Hardware - Others
Where can i find a manual for my black & Decker deluxe dual action sander no. 7420
Many Black&Decker power tool manuals are available from their http://servicenet.blackanddecker.com/Home support site. If you search for the 7420 model number, the correct sander is the first one in the resulting list. The direct link to the 7420 sander page is http://servicenet.blackanddecker.com/Products/Detail/7420# . The link to the manual is on the right hand side of the page near the top. That is scripted link; the actual URL for the manual appears to be http://documents.dewalt.com/documents/English/Instruction%20Manual/592750-01,7420.pdf . However, that may change in the future.
I hope this helps.
Jun 08, 2015 | Sander Tools & Hardware - Others
CHANGE THE SANDPAPER IN THE BELT SANDER
there should be a lever that will loosen the tention on the belt so you can get it off. be sure to put the new belt on with the arrows facing the rotation (some sanding belts do not need to be oriented this way, but check) otherwise the belt will come apart after a few rotations.
Mar 22, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
Could you please tell me what sandpaper goes on the Mouse sander/polisher model # MS500
ok this easy go to the hardware store and ask for the sandpaper to fit your sander, black & decker make sandpaper specifically for that sander. now depending what job you want to do will determin what grade you want sand paper works like this the higher the number on the paper the finer it is so for example 80 is very coarse you would use that for eg stripping thick paint on a door but 2000 is very fine and is used for eg sanding varnish between coats. ok hope that helps let me know how you go.
Mar 11, 2011 | Black & Decker Mouse Sander/Polisher
Dec 10, 2009 | Black & Decker Black And Decker Cyclone 4...
How do I change the sandpaper in my Black & Decker Sander 7448? I lifted the two levers and the sandpaper came out but now I cannot get them to close tightly around the replacement sandpaper.
Nov 15, 2009 | Tools & Hardware - Others
Replacing the sand paper
Ok on the front and rear of the sander you will see metal wire holders. These extend each side of the sander and form a loop to which you can release them from their holder. Release each side ring and then that will lift the wire holders up at the front and back of the sander. This releases the sandpaper sheet. Now cut or add a new sheet that is long enough to fit over the sander base and fold up under the wire holders. Then clip the rings from the wire holder back in place while holding the sandpaper under the wire holder to hold the sandpaper in... same process for each holder (one front and back). That's it!
Jun 13, 2009 | Black & Decker QS800 2.0 Amp 1/4 Sheet...
Tools & Hardware - Others Logo
578 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
