Question about Keurig B66 3-Cup Coffee Maker
How to empty the water from the resivor to descale the coffee maker
  • Keurig Master
  • 43,501 Answers
Check out this tip about how to descale your Keurig coffee brewer
How toDescale your Keurig Coffee Brewer
heatman101
Posted on Apr 03, 2011
How to descall the bosh coffee machine
Empty the reservoir of water and fill it up again with vinegar. Run the vinegar through 5 or 6 times, then empty the vinegar, put distilled water in, and run it until the water is gone. Then your machine should be de-scaled.
Jun 25, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
My maker keeps on saying descale. but how do i do it.
17.3 Descale
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the message:
DESCALE
flashes on the display, you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the P button (the light over the button comes on) then press the button repeatedly until the
appliance displays:
DESCALE No
• Press the button (corresponding to the SET symbol flashing on the display) and the appliance will
display:
DESCALE YES
• Press the OK button to start the descale programme.
• Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one litre of
water.
For subsequent descaling, use descaler of the same type and brand as supplied (available from technical
service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
34 C o l l e c t i o n
• press the OK button.Descaler runs off from the hot water spout into the container below.
The appliance displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
Oct 22, 2013 | DeLonghi Prima Donna Avante ESAM6700...
How to discale the unit
Delonghi EAM, ESAM, ECAM, Nespresso
When the appliance displays the message:
DESCALE
Proceed as follows:
• press the button (the light over the button comes on) then press the button repeatedly until
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
RISRINSING COMPLETE PRESS OK
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Jan 01, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Descale
DESCALE
Proceed as follows:
DESCALE No
DESCALE Yes
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
We have model # BKC800XL - it give us a message about "descale" not sure what that means and how to correct
Just like any coffee or espresso maker, descaling is a process that needs to be done periodically. If your location has hard water, you may need to descale more often than elsewhere, but it's nothing to worry about. It's just a chemical process that occurs as the result of mineral deposits from the water collecting on the elements inside the coffee maker. I'm sure that coffee manufacturers will sell you tablets for descaling, but I've always just used undiluted white vinegar as the reactant. To do this, I recommend: 1. Empty all of the water from the reservoir. 2. Fill with undiluted white vinegar. 3. For this type of coffee maker, brew as many cups as it takes to empty the reservoir, being sure to dump each cup in the sink as it finishes. 4. Once you've run through all of the vinegar from the reservoir, refill with water and run a few cycles to rinse. (You may want to leave the water to soak for a while to give the residual vinegar further time to clean off the minerals.) 5. Fill again with water and rinse. 6. Once you've emptied the reservoir a second time with the water, your machine should be adequately descaled and ready to brew coffee again!
Jun 17, 2011 | Keurig B60 Coffee Maker
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
What is de-scale?
Descaling removes the deposits left behind from hard water. These mineral deposits will slow heat transfer if not removed from the heating element. To descale the coffee maker, use 48 oz of undiluted vinegar (household strength) and have a large ceramic mug to hold the output. Empty any water in the reservoir. Pour vinegar into the Water Reservoir and fill to the top of edge of the clear viewing area. Place a mug in the drip tray and press the Large Cup Button. (Do not use a K-cup.) When the brew cycle finishes, pour the contents of the mug into the sink.
Repeat the brew cycle until the reservoir is empty. Open and close the lid between cycles. When the reservoir empty, fill with water and let the coffee maker stand for 4 hours with the unit ON. After four hours, rinse the coffee maker by doing several brewing cycles (again without a K-cup). Discard the liquid after each brew cycle and repeat until the reservoir is empty.
You may need to perform additional brew cycles if you notice a residual taste.
For more information, including a pdf with the directions for descaling of the coffee maker, see http://www.keurig.com/customer-service/brewer-registration-and-support/frequently-asked-questions .
I hope this helps.
Oct 21, 2010 | Keurig B50 Coffee Maker
How do i get the red light to go off on my coffee maker i already descaled it
You have to ensure the descaling function runs completely to the end. Occasionally the water tank will be empty BEFORE the descaling program has finished, in which case you should refill it and let it continue descaling.
The light wiill automatically go off once the descaling program has been fully completed.
Mar 20, 2010 | Braun Tassimo Espresso Machine/Coffee...
B100 putting out very little water, reservoir is full
bye descaling product for the coffee maker not vinegar put descaler in machine fill with water start leave it running for 10 seconds close it for 15 minute start it up again repeat untill empty after its empty fill it with water run it untill empty repeat again descaler is acid so you need to rinse very good try it out thanks pierre
Jan 11, 2009 | Keurig B100 Coffee Maker
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Keurig B66 3-Cup Coffee Maker Logo
281 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
