Question about NorStar NT8B30 M7208 LCD Speakerphone - Refurbished (NSM7208)
Nortel M7208 Swapping phone equipment but keeping the extension
I have a defective M7208 which I would like to change with another M7208 but need to keep its profile (extensio) Can I do this?
  • 105 Answers
There is a built-in feature called Set Relocation. Check with your system administrator to make sure this feature is set to No. Then you can swap phones without a problem. Good Luck!
Posted on Aug 13, 2010
  • 27 Answers
Yes you can change the phone and every thing will stay the same . as long as you change it with the same model phone .
Posted on Aug 28, 2009
1 of four extensions is intermittently dead. Where do I start looking to fix the problem?
This is interesting. You need to consider things that change during the day. There is a demark point that the phone system connects to. This point may be in a closet etc. What environmental changes are happening near that point> Temperature, humidity, other devices coming on that send out interference etc.
Jan 20, 2017 | Nortel Meridian M7208 Corded Phone
The phone display window is blank but the phone works any suggestions for turing that on?
your phone's LCD display is defective and it should be changed. I have a similar problem but till it works that way, I can live with it. Actually I have 3 more with good display - hehe....
If annoys you, get a used one from Amazon for 44 USD
http://www.amazon.com/Nortel-Meridian-M7208-Telephone-Gray/dp/B0018JVOP2
Sending it to repair might cost you more.
Aug 25, 2015 | Nortel Meridian M7208 Corded Phone
Nortel 7208, locked out of mailbox. Forgot password. tried 120000; says "locked out" can't get in. It is work phone need to get messages. Please help.
To reset the password on the mail box you need to go to a M7310 phone on your system. It has 3 buttons under the display. You need to press the "Feature" button and 983, then enter the password 120000 (this one is used if you have 2 digit extensions 1020000 is used if you have 3 digit extensions) . Next in the display you will see mbox-AA-othr above the soft keys. Press the button below mbox. Next enter your extension number. After that you should see the screen to reset your password. This will reset the password to 0000. When you go back to your own extension and log in to your mailbox it will prompt you to change your password. If you password120000 or 1020000 doesn't work try 121111 or 1021111, the last 4 digits are the password for the admin mailbox.
Mar 02, 2015 | Nortel Norstar M7208 Telephone
Norstsar M7208 Corded phone cannot use handsfree feature
Your problem is in the phone system programming. I would need to know how old your main cabinet is in order to tell you how to fix it. On most Nortel systems you use "Feature Key" **266344 (Feature **CONFIG) . You will need to program from a M7310 phone because you need the 3 soft keys under the display which the M7208 does not have. The top 4 keys on the phone are used for programming (2 LEFT & 2 RIGHT) . I'm referring to the 2 vertical rows of keys (5 LEFT & 5 RIGHT). Upper left key is up a menu, upper right key is SELECT, lower left is BACK, and the lower right is NEXT. I believe you need to find the CAPABILITIES menu for your station/extension and use the next button to look for the handsfree setting use the key under the display to change it. The manuals are at http://wedophones.com/Manuals/Nortel/
Aug 30, 2014 | Nortel Norstar M7208 Telephone
I am trying to figure what my extension is? I have an M7208 Nortel
Do a button inquiry to find your prime line(intercom number). Press feature *0 then the button you want to identify. Your prime line will be either the bottom programmable button or the next one up.
The button defintion will appear in the LCD screen for each button inquiry you do.
Dec 22, 2010 | Nortel Meridian M7208 Corded Phone
Getting the M7208 to work
Nortel M7000 series are proprietary sets which require a nortel MICS, CICS, or an older 8x24, 6x16, or 3x08 in order to work. If you have the system, it maybe that the jack isn't activated with a system port.
Nov 24, 2009 | Nortel Meridian M7208 Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
Unable to transfer calls to a certain internal extension using a M7310 Nortel Corded phone
The do not disturb might be active on the extension that your trying to transfer to.On the extension that your trying to transfer to, enter feature #85 to cancel out do not disturb.
Sep 28, 2009 | Nortel Meridian M7208 Corded Phone
Finding the extension number
press feature *0. you can now look at any button on your phone to see what it is, touching the intercom button will tell you your extension
Aug 18, 2009 | NorStar M7208 Corded Phone
I'm looking to rotate phones around the office so that they can remain with their employee. Basically, I want to plug in the original phones to another line and reprogram for the original extension with...
In my workplace, when you move the Nortel M7100 phone, the programmed info (extension number, etc) moves along, just like if I was rewiring all phones. Have you tried just to unplug the phone and plug it on the new location? Here the extension number moves along with the equipment... (Nortel Norstar M7208 and M7100). Good Luck!
Jul 02, 2009 | NorStar M7310 Corded Phone
NorStar NT8B30 M7208 LCD Speakerphone - Refurbished (NSM7208) Logo
168 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
