Question about Whirlpool Duet GHW9150P Front Load Washer
Recently we have to spin twice before putting the load into the dryer. Any suggestions?
Do you mean still full of water ? check drain hose isnt kinked this will stop water draining away
Posted on Apr 03, 2011
  • jsoppit Apr 03, 2011
    I checked the drain hose and it's not kinked as well I checked the filter prior to the drain pump and it's clean. When we spin only once the clothes are still too wet to put into the dryer so we spin a 2nd time.
Front load dryer wont spin with towels in it
Is the motor growling on start with nothing in it? Is the drum hard to turn? It could just be a worn out motor is all of the above suggestions are covered.
Nov 11, 2015 | Dryers
My dryer is spinning and it is getting hot but he clothes are taking twice as long to dry?????
disconnect the vent run a load of clothes, as it sounds like the vent tube is restricted, Tim
May 21, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My machine is spinning, but clothes are still very wet, have to drain and spin at least twice to get them dry enough to put in the dryer
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Feb 08, 2011 | GE Washing Machines
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My ariston margarita dosent want to take a wash load
Most likely the EPROM is gone, or more commonly known as the PCB (Programm Control board) and it needs replacement. Costs about £80 for the board plus installation.
Dec 14, 2009 | Ariston Technologies Ariston AWD12 Front...
I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer will not dry with full load, keeps kicking off
if your belt is slipping change the belt also check the felt and rollers make sure thay are turning freely the next step after that is change the motor thank you for useing fixya please rate me
Mar 18, 2009 | Whirlpool LGR7646E Dryer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Spins twice then clicks through all cycles
open to see behind the panel which holds the switch. look for any wires disconnected
May 10, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
