Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printer not working, showing Error 6 A00, I have put new ink , have done all the possible things I could do, like disconnecting from electrical; cord,restarted, no paper jam, still error message keep coming. Any advice ? Thanks, Avais
  • 2,632 Answers
Welcome to Fixya. The 6A00 is a Canon generic code for paper path jam. You can try to use the guide below to clear the obstruction and see if the problem will be fixed.
- Open the top of the printer, move the ink-cartriges to the left.
- Look in the openening you get.
- You wil see white plate with two transparant guides on this.
- do not thouch the transparant guide plate
- On the most right white arm push a little downwards with a pencil or a plastic pin.
- May be you have to push on the grove a little more to the back .
- You will see that the plate will move a very little and this obstruction for moving the cartriges and rollers is gone
If you have questions please let me know. Thanks for using Fixya.
Posted on Apr 03, 2011
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
Pixma ip660d displays 6500 error code
Hello
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Feb 17, 2011 | Canon Pixma iP6600D InkJet Photo Printer
Error 6500 - CHECK PRINTER message - how do I fix it
4. Properly seated
Nov 25, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Display shows error code 6500. how do I fix the error
4. Properly seated
Aug 15, 2010 | Canon MP830 All-In-One Printer
Error code
4. Properly seated
Good Luck!!
Thanks
Oct 01, 2009 | Canon Office Equipment & Supplies
Cannon mp830 error code 6500
4. Properly seated
Good Luck!!
Sep 20, 2009 | Office Equipment & Supplies
Screen shows error code 6500
4. Properly seated
Good Luck!!
Thanks
Sep 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon MX850 keeps saying Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again. I...
It is possible that your ink cartridge is damaged. Try using an old ink cartridge that worked before and try to print again.Even if the ink cartridge you are using is full of ink, when sensitive electrical components are damaged, it wouldn't work.
You can also try using a different printer to rule out the possibility that your computer is the problem.
Sep 06, 2008 | Computers & Internet
Green light under start button
the E means Error. disconnect the printer's electrical supply and reconnect after a few minutes. Reload it with paper and print a test page.Make sure you have ink in your cartriges.
Aug 31, 2008 | HP PSC 1410 All-In-One InkJet Printer
Hello, we're getting an error code of 990 on a GX5050n inkjet printer. The printer is fairly new with only a dozen or so printouts. Thanks.
make sure printer is off. Then old down escape and online button at the same time. Continue to hold these two buttons down then turn on printer. Continue to hold those two buttons down (will take about 2 - 3 minutes). This should clear that message - worked for me!!!
Aug 07, 2008 | Ricoh Aficio GX3050N Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
