Question about Altec Lansing VS2421 Main / Stereo Speaker
Altec Lansing VS2421, having audio cracking and garbles narrowed down to volume adjustment knob. Im somewhat proficient in electronics, if i had an electrical diagram im sure i could fix it. Replaced system this one is just sitting around, but id like to get it working again.
Posted on Nov 15, 2013
3 Suggested Answers
  • 11 Answers
SOURCE: Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Posted on Sep 17, 2008
SOURCE: Can the Altec Lansing VS3251 5.1 work with a Xbox?
Because this system is made to work with the PCs, it has a 3.5 mm stereo input. The 360 has rca cable outputs. Fortunately, the signal is the same and all you need is a 3.5 mm to rca y adapter that you can find at radioshack or any local electronics store.
Posted on Apr 16, 2009
Altec lansing 221 computer speakers sound solution
Unfortunately it looks like Altec Lansing goofed up on this set and didn't provide a bass control knob. You will need to use some sort of software equalizer on your computer to turn the bass down.
Mar 24, 2012 | Altec Lansing 221 Computer Speakers
My pc wont dected the speaker / microphone system on my altec vs2421 please help
update your audio drivers and make sure your computer is seeing your sound card. Speakers are always plug and play so I would check out your sound card and also make sure your sound is not muted :)
May 05, 2011 | Altec Lansing VS2421 - 2.1 speakers with...
Got my computer fixed (altec lansing vs2421) and now it does not recognize the speakers. Try all troubleshooting on the computer already. If It is the problem due to ur sound card and not the speakers,...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 27, 2011 | Altec Lansing VS2421 2.1 Speakers
No sound whatsoeveer
First, I would verify that the speakers have power. If they do, I would then check to see if the cables are firmly seated and in the appropriate jack (ie. not the microphone). If all of that is OK, then I would see if the computers audio is on mute (if so the speaker icon in the lower right hand corner will have an "X" on it) as well as adjusting the volume knob on the speakers. If your computer has multiple audio devices, make sure the appropriate device is selected for playback. If all else fails, I would then try to unistall and reinstall the audio device driver within device manager.
Also, If possible, I would test the speaker system on another device (ie. portable stereo/cd player/MP3 player) to narrow down the root cause of the issue.
Oct 28, 2010 | Altec Lansing VS2121 Computer Speakers
My speakers used to work and suddenlly stop then beganto where somtimes when i longed on they worked and other they would all i hear when i turn them up is static and now my compouter is saying the are no...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 13, 2010 | Altec Lansing 2100 Computer Speakers
Connecting an Altec Lansing ADA995 subwoofer system to a stereo
I have this exact Altec Lansing speaker system and I'm currently just using it with my Dell computer. But, I know you don't have to install these speakers to any high powered receiver for good sound quality. The subwoofer has two separate 200 watt RMS combined amplifiers built in for it's single knob controlled dual 6.5" bass drivers and 2-way magnetically shielded satellites, which are amplified together by any source that has an analog or digital volume control. The speakers act as a preamp receiver to any volume or frequency tone level controlled audio source. These input sources can also equalize the speakers receiving input signal for bass, treble or mid-range adjustments. You only need to obtain the proper adapter to hook up all the speakers to your desired component or device. Besides a computer, for example a TV with a variable audio out function or a mp3 player will work. The adapter that i am referring to is similar to what is included with certain 5.1 Logitech brand computer and multimedia speakers specifying gaming console and TV connecting. It has all three color coded 1/8" connector inputs on one end and RCA jack outputs on the other. This can be purchased more easily online then offline at stores such as Ebay for a fairly inexpensive price. However this adapter will not decode true 5.1 surround, but instead give a 5 channel stereo effect. I guess if one was looking for an inexpensive alternative solution to purchasing traditional high end home entertainment audio equipment, the ADA 995s are one of few computer speaker models in my book that can do a decent job.
Jun 19, 2009 | Altec Lansing ADA995 Speaker
Altec Lansing ATP 3W Computer speakers
I am also experiencing the same problem as yours...
Dec 01, 2007 | Altec Lansing ATP 3W Computer Speakers
When truning up t3h volume...
volume control knob is damaged inside ,try to put 3drops of kerosine mixed with edible oil in equal amount.care should be taken not to get it on the electronic board and adjust the knob continuously ,if this doent work u must replce the volume controll
Dec 18, 2006 | Altec Lansing VS2221 Computer Speakers
Altec Lansing VS2421 Main / Stereo Speaker Logo
428 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
