Question about Watches
How do I remove the back from a channel J12 ladies watch after I have removed the 8 tiny back screws? My goal is to change the battery.
  • 2,334 Answers
After removing all screws you have to use fine pointed tweezers and pry up watch case back using them. Insert between case and case back and pry up using lever action.
Posted on Apr 04, 2011
What size battery dos my Gucci 1 980 003 series ladies watch need
Take your Gucci watch to a jeweler who will open it, identify the battery type and perhaps install a replacement for a reasonable sum.
Sep 21, 2017 | Gucci Watches
How do u change the battery in a gossip small ladies watch
  • Remove back
  • Locate battery and note how it is installed
  • Identify battery
  • Obtain replacement battery
  • Remove old battery
  • Install new battery
  • Check operation
  • Reinstall back
  • Set functions
  • Return to small lady
Oct 14, 2016 | The Watches
How can I change the battery on a ladies Sekonda 4602AKT watch.
If it is indeed a screw type back it will have indentions ON the back (6 to 8). A special tool is required to remove the back without damage to the watch back. Any reputable jewelry store should be able to remove the back. If there are no indentions then it should be a pop back. Some watches do not have a slot to slide a pry tool under the back. You have to use a sharp knife..taking appropriate safety precautions.
Jul 03, 2016 | Watches
Removing back of irish collection ladies watch for new battery
Replace Your Watch Battery Yourself With Household Tools ...
? 7:32
https://www.youtube.com/watch?v=L4Y7pDonkmk
Aug 15, 2013 - Uploaded by tsbrownie
How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...Missing: irish
How to Change a Watch Battery with Normal Tools - YouTube
? 9:18
https://www.youtube.com/watch?v=gFmV7NIjVsw
Sep 1, 2011 - Uploaded by RichsMethods
I also show how to polish the metal portions of your watch. ... of how not to take the back off and remove ...Missing: irish
Dec 21, 2015 | DG Watches
How can I remove the back to replace the battery?
If there are tiny little screws attaching the back, you need the smallest metric Phillips head screwdriver in the set you purchase at a dollar store. Be sure to save the screws carefully as you will need to reinstall them.
Nov 08, 2015 | Invicta Special Edition Lupah Ladies...
How do I change the battery on a Windesign Racing ex3018 watch?
You need a tiny flat screwdriver. Remove the 4 screws on the stainless steel back. There is a little spring clip holding the battery in. Use the tiny screwdriver to unlatch one end of the spring clip. Replace the battery (3 volt lithium Maxell CR2025 or equivalent) positive side up. Re-latch the clip and then replace the back, being careful not to cross thread the screws and secure the back well to keep water out.
Jul 11, 2013 | Watches
Can:t remove back from Fossil watch BS9839, TO REPLACE BATTERY
you need watchmakers screwdrivers you can get them and other tools aswell off ebay ,,,,click on the link below,,,,,,,
http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=watch+makers+screwdrivers&_sacat=0
Aug 01, 2012 | Watches
I have a Steinhausen TW524L Watch how do i change the battery or is this watch automatic it has stopped running.
It's not as easy as popping off the back like some watches to replace the battery. The 4 screws on the top bezel are not the ones to remove. Look at the back side of the watch and you'll see 4 really tiny pinholes. You'll need a jewelers screwdriver small enough to fit into the holes to remove the 4 screws. Once you do that, the two halves of the watch come apart with a little pressure. It takes a little prying to get the case to separate. Once you do that, you'll see the battery. Be careful with the waterproof gasket as you'll need to put that back in the same position to keep the case sealed. The gasket is really delicate. You might consider taking it to a watch maker to change out the battery if you don't have the tiny (and I mean really tiny) screwdriver to remove the 4 back screws.
Nov 12, 2011 | Watches
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    Watches Logo
    444 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
