Question about Panasonic Lumix DMC-FZ30 Digital Camera
Hi. My panasonic DMC FZ50 is displaying a white screen on the LCD.Is this something i can rectify myself.
SOURCE: panasonic lumix dmc fz50
FIRST YOU HAVE TO CHECK THAT YOUR PC PICKS UP THE CAMERA AS A EXTERNAL DRIVE IN MY COMPUTER. IF NOT THEN THERE MAY BE A PROBLEM WITH THE CABLE OR THE JACK ON THE CAMERA. THIS DOES GET DAMAGED IF YOU DO NOT PULL THE CABLE OUT STRAIGHT. DO NOT WIGGLE THE CABLE.
Posted on May 27, 2008
  • 3 Answers
SOURCE: external flash for dmc-fz50
I can't totally answer your question, but please look to the Olympus fl-36 OR metz 48 af-1--both are 100% compatible. The FL-36 is way less money than the pany equivalent--trust me its the same exact flash as the Pan FL360.. For a little more money, the metz is slightly more powerful, but you loose the "auto thrystor" feature. The oly is a lot smaller as well.
I have the FZ-50 and have used both flashes.
Posted on Jun 15, 2008
SOURCE: Panasonic lumix DMC-FZ50
I have an DMC-FZ7K. I had the exact same problem, here's how I solved it:
Turn on the camera. Set the mode dial to "P".
Now press the button labeled "MENU SET".
In the menu that comes up, scroll up and down until you find a menu item named "PICT.ADJ." When it is selected, press the right arrow button.
In the sub-menu for "PICT.ADJ", select the "SATURATION" item and change it to "standard" or "low". Press "MENU SET" to save the changes.
You should now see a difference in the next pictures you take.
Posted on Jul 09, 2008
smartr10U
  • 1305 Answers
SOURCE: I have lost my instruction manual for my Panasonic
You can download a fresh copy from Panasonic HERE
K
Posted on Jun 16, 2009
  • 5 Answers
SOURCE: I have an urgent issue of needing to display date Lumix DMC-FZ50
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FZ50K for pdf version of manual. The K or S means the color of camera you have...black or silver. My wife has that camera, there is no way to display the date/time on the pictures themselves, you will have to look at the properties of the image. All images now contain certain data that is hard for the novice to change and might be able to be used in certain courts...good luck, hope it's not too late.
Posted on Jul 24, 2009
FZ50 lumix LCD image fliped
The lcd screen has snesors inside that tell the camera which way to display. If it is not correct, you should take it to a service company, since one of it might be broken. Let me know how it turned out for ya.
Jul 24, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
White Screen
Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in the first case the only solution is the replacement of the CCD.
Please click HERE
And in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Click HERE for the manual.
Main support number: 800-755-3854
I hope you are satisfied with my solution..
Goodluck..
Feb 21, 2008 | Fuji FinePix S5000 Digital Camera
I cannot see through my viewfinder to take a picture, but can take pictures on the LCD monitor on my DMC-FZ50 digital camera. Joan
There is most likely a setting in the camera's menus so that you can switch between live view and the eyepiece. Search around, or check your manual.
Jul 07, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
I have lost my instruction manual for my Panasonic DMC FZ50 and wish to replace it. I live in Wellington area NZ.
Hi. I found the website to download the user manual for your Panasonic DMC FZ50 . Here is the link.
http://sils.unc.edu/itrc/its/lab_resources/manuals/LumixDMCFZ50-manual.pdf
Just double click on the link or copy and past in the address box and save it on your computer.
GOOD LUCK!!!!!!!!!!!!!
Jun 16, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
May 18, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic DMC-FZ50 Digital Camera
No, there is nothing like that. If you need advice, ask me, I will try to help you with the settings. vladio2000@yahoo.com
Aug 31, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Finding the black & white setting on my Panasonic FZ50
you go to menu,then go to Color settings Black and white
May 24, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic Lumix - LCD & viewfinder WHITE
my camera just did that to me yesterday..i had t for like a week.. did u have a warranty on it or something like that?? i have to take mine back to the place were i got it and go talk to them about it.. my screen is like shot or something..
Feb 21, 2008 | Cameras
Trouble with my panasonic fz50
CAN YOU SEND EXAMPLE PICTURES, OR DESCRIBE THE FAULT IN DETAIL.
Oct 31, 2007 | Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic Lumix DMC-FZ30 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
