Question about Cameras
I have one of the chinees dvr, in which i can login from LAN (from the same router) however when i try to login from remote location i.e internet i get the login failed i tried different computers with no use.i will be gratefull for any help. Thanks Basil Doha-Qatar
  • Basil Aljawahiri Apr 04, 2011
    I found the problem, it seems that you have no enough experience, sorry pal.
    Regards
  • 13,433 Answers
If you could be more specific as to what happens when you try to connect or login. and if you get anykind of messages.
in the settings of the dvr you may be able to turn on and off the ability to login from outside.
or then possibly your router or firewall or modem may have a feature that blocks some communication.
Posted on Apr 04, 2011
  • Ekse Apr 04, 2011
    congratulations
Help Please! I had to reset the hard drive to factory settings on an Advent Roma 1000 laptop. It can locate & connect to the router but cannot access the internet. It says 'no internet access'
the drivers for lan and wireless
Realtek RTL8168D/8111D Gigabit
Realtek RTL8187SE Wireless LAN
pls download the drivers here
http://www.adventcomputers.co.uk/product-download-select/102
pls try to configure ip address for your router and
also if you can login to router pls check the router settings for internet
Oct 28, 2017 | Advance Computers & Internet
Best Picture Quality - JPEG2000 DVR - Netopia 3347
Just reinstall agin the firmware or update it & take a soft reset of the unit
Mar 07, 2008 | Netopia (3347NWG-VGX) Wireless Router...
I have an Eyemax DV-9060 that I am unable to remotely view from my iPhone 6. I currently have the DVR set to a fixed local IP of 10.0.1.13, and have my router (modem/router combo unit from Comcast)...
If you are setting this up as a static IP then you need to have the router IP address input into the DVR to allow it to pass through. You also need to have a gateway set up to allow incoming and outgoing signals to the host site.
Mar 23, 2015 | Gateway Computers & Internet
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
TP-LINK TL-MR3020 need DUC or not i connect only hikvision dvr
Remotely would imply a different building or location. What exactly are you trying to accomplish? Do you mean hook it up in one room and record and watch shows in another? Or over the internet? Give more info.
Feb 02, 2013 | TP-LINK TL-MR3420 Wireless Router
I want 2 configure a DVR from remote place and not from the intranet. kindly help me out in solving the issue
To configure the DVR from a remote location you can do it one of two ways:
Create a vpn connection through your router if it supports it or an external units to the remote location. This will make the remote location appear to be local to the dvr.
You can also setup the dvr's internal IP and port on your router through port forwarding. This way certain network access or traffic will be passed directly to the dvr from outside your local network.
Nov 12, 2009 | Dome 4 CCD CCTV Camera Surveillance...
Not able to use remote viewing via no-ip
I had the same exact issue. I was using dyndns to connect, but i found out that when you login in the host, dont put your local ip address of the dvr, but instead put the internet ip address of your network. so instead of 192.168.0.5 for your local put the 89.137.24.124 for the internet address. That fixed my issue. Hope that works for you. Just make sure your username and password is right and the port is set up correct in your router to forward to the local ip of the dvr.
Mar 06, 2009 | GE Security Bc 1500 2.5 Ball Camera, High...
Hi. I got a MEGA105WR ADSL Router and SAMSUNG camera system SHR-5040 DVR. I need help setting my router for my DYNDNS account. So I can link remotely by software and webb browers.
These instructions will work on any windows computer version 2000 and up.
In order to open ports you need to gain access to your router's control panel. To do this we go to Start>Programs>Accessories>Command Prompt. From here type in: ipconfig
Press ENTER to execute the command. A list should be returned listing some IP Addresses. Look for the one associated with, "Default Gatewaty."
Here is a picture.
Afterward open your Internet Browser (Internet Explorer, Firefox, etc...) and type the IP Address associated with the default gateway into the address field of the browser. DO NOT add www. or .com. Afterward press ENTER or click GO as if you wanted to visit a website.
Here is a picture.
Once you're at the control panel you will probably be asked to log in. If you do not know your login details you can always try the default. To find these you can either search your router's user manual or head to the online search engines entering your router's manufacturer's name, the router's model #, and the words, "default password" into the same search request to bring up the default login credentials. For example:
Linksys WRT54G default password
Here is a picture.
If you still can't manage to log in to your router's control panel you will have to contact the technical support department of your router's manufacturer asking them for assistance in resetting the login user ID and password of the router.
Once you manage to log in to your router's control panel, locate areas hinting anything in port-forwarding. Such as:
Port Forwarding
Firewall
NAT
Virtual Servers
Applications
You're trying to find a panel similar to the one depicted in this screenshot. Please note that the panel will probably not be alike. However in order to forward ports the router needs this information:
Ports to forward, on which protocol, and where to forward the ports.
Once you manage to find the appropriate screen for port-forwarding you will have to check with SAMSUNG to determine which ports need to be opened to allow remote access to your DVR.
Jan 28, 2009 | Computers & Internet
Can't access my DVR remotely via Video Server E
why i cant remote access my dvr in WAn but LAN is working fine?
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
