Question about General Heating & Cooling
Boiler working hot water, but no heating,. i have just returned from working abroad 6 months, the water pressure bar had gone back to nil. i filled loop. 2 bar. and reset, electric switch fired boiler. but no heating, cant understand.
  • General Master
  • 43,501 Answers
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though itmay be hot and seem to be running. In this cause the pump can sometimes betaken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in moredetail.
Heating Circulating Water Pump Problems
heatman101
Posted on Apr 03, 2011
Why can't i fill my boiler
You didn't specify what kind of boiler you have. Some low pressure steam boilers have a manual fill valve as well as an automatic float switch valve. Hot water boilers have a pressure reducing valve that constantly monitor the boiler pressure and maintain 12 to 18 PSI for the safety of the boiler. If the boiler runs out of water there is a good chance it will rupture and become unrepairable. If you are saying your boiler won't fill, and its a hot water boiler, the pressure reducing valve is probably blocked with sediment and needs replacement. The valve is in the water line that feeds directly into the boiler return line from city water. Hope this helps.
Oct 01, 2014 | Water Heaters
Ravenheat 80/20 boiler. the boiler looses water pressure but only when working in central heating mode. Boiler holds pressure indefinitely if central heating is not used,hot water can be drawn without a...
Hi, your boilers pressure should be holding 1.5 bar with the relief set about 3. If the pressure is below this the flow switch will cause the boiler to stop as theirs not enough pressure to operate. Another thing, does your boiler have an auto fill system or do you need to plug a hose in to fill it? If its an auto fill system and you lose pressure you could have a leak.
Sep 15, 2013 | Water Heaters
I have a vaillant eco tec pro boiler and the pressure guage is showing zero and boiler not working, is there a simple fis ?
Refill system with water to 1bar bleed rads refill again to 1 bar , there should be a filling loop to do this with.
Oct 23, 2012 | Grilling
I have a Vaillant Combi boiler, (not sure of make, but its 10 years old),the hot water works fine and the bolier heats up the downstairs rads fine, but the upstairs ones have all gone off...have bleed them...
lost pressure raise pressure up 2 bar and bleed the rads keep topping up untill all air has gone from rads do this with the pump off, turn all your rads back on and follow what in said .
Aug 27, 2011 | Heating & Cooling
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Combi boiler will not fire up for hot water or heating.
check tops of spindles at radiator valves for leaks easy repaired set pressure to .8bar setting at 1.5 may be make overpressure and blow off through high/pressure releasese valve
Nov 30, 2009 | Water Heaters
The pressure drops very slowly over a month then needs topping uo from the filling loop to 1.5 bar. when the heating is on it goes upto 3 bar. the pipe outside is slightly damp. it was fine during the...
Sounds like the expansion vessel in the boiler has lost pressure or is faulty. If you have a tyre pressure gauge, locate the expansion vessl and check the pressure via the schraeder valve. It should be around 1.5 bar. If there is no pressure you can re pressurise it with a bicycle pump. Should it not pressurise then you will need a new one. The pressure relief pipework outside is damp because the system is over pressurising at relieving pressure at 3 bar. This obviously causes a system pressure drop. You can install a pressure vesel into the heating return pipework should accessing the boiler be difficult.
Oct 31, 2009 | Water Heaters
Baxi 105 he
on the pipework near the boiler there should be a silver flexi hose connecting the two copper pipes ...this is called a filling loop there sould be taps on the filling loop turn on by moving the black plastic taps do this slow ..at the same time look at the pressure gauge on a baxi do not go over 1 bar...............
warning ..if the boiler has lost pressure where has it gone..is there any leaks anywhere..if it persist contact a engineer
Jun 06, 2008 | Heating & Cooling
Heating & Cooling Logo
145 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Bill Long
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
