Question about HP LaserJet 1300 Printer
Put in new cartridges,now it says check paper - paper is fine no jams
  • HP Master
  • 6,993 Answers
Turn the printer off, remove and insert the cartridge. If problem persists, reinstall the printer in this form;
First, disconnect the printer cable from the computer. Go to Control panel on your computer, go to printer under control panel, right click on the printer models there and delete them. Make sure all printer installed under "Printer" is deleted.
Now go back to control panel, uninstall your printer software(s). Make sure you uninstall all software relating to the printer. After that restart your computer.
Once your computer has booted, re-install the printer afresh and the it should be in order.
If the above doesn't solve the problem, please let me know so that I can direct you further....
Good luck.
Posted on Apr 03, 2011
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 21, 2014 | Epson LX-300+ II Matrix Printer
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
Important:
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
Hp 2430dtn backdoor paper jam when I put a new cartridge in, motor will not turn on
Silly questions first: did you remove the seal before fitting the cartridge? Second, if you still have the original cartridge try swapping it for the new one and try again. It may be that the cartridge is faulty - it does happen.
The cartridge you have should have the number Q6511A or Q6511X, if it doesn't you may have been given the wrong cartridge. Another possibility is that you have paper caught in the duplexer tray. That is accessed by removing the paper tray 2 and dropping down a flap inside. remove anything still in there and restart the printer.
Mar 30, 2014 | HP LaserJet 2430dtn Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Cartridge cradle can't move, says paper is empty when it's not
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Jul 23, 2009 | HP Deskjet F2210 InkJet Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
HP LaserJet 1300 Printer Logo
Seeker5211
Seeker5211
